my question is this. can i weld aluminum with my millermatic 135 and if so what do i need? any help would be appreciated
aluminum with mm 135
Originally posted by handyman52607 View Postmy question is this. can i weld aluminum with my millermatic 135 and if so what do i need? any help would be appreciated"Better Metalworking Through Research"
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
there is the question of amps. but if you only need to weld 1/8 or maybe 10 gauge if its not to cridicale you could us a spoolmate right? 3035? i use a 30a but i have a Dynasty 200 and a trailblazer 302.TB 325
TB 302
dynasty 200sd
spoolmatic 30a/wc24
suitcase x-treme 12vs
miller 211
evolution rage 2
aluminum mm 135
all i have are basic fabricater tools: torches, chop saw, grinder, and of course the miller 135. i would'nt be doing anything major, just repairs and some small scale fabricating. welds no more than one inch long, if that.
i've heard that its possible to do, but im no expert. but if a spool gun will work on my machine which one do i get? really, any advice is appreciated.
I have used a 135 to weld al without a spool gun. 1/8th flat stock for non critical work. It is doable and I did make some devices that are still in used many years later. It is a pain and you have to keep the gun cable nearly straight or you will birdnest the wire. This was a good while ago I don't recall if there was a spool gun that worked on the 135 nor was I going to fork out the $ for one for the simple work I had at hand. I would think that a spool gun would take most of the PITA factor out. Even with a spool gun a 135 is limited of power and al loves power.
Does not hurt the wallet much to get a spool of wire and a clean liner and try it out.Weekend wannab racer with some welders.
At the Miller site it indicates that the Spoolmate 3035 will fit onto a MM135. It's "list Price" is $650!!!
Compatability chart:
http://www.millerwelds.com/products/...gun-chart.html
Product itslef:
http://www.millerwelds.com/products/...poolmate_3035/
You may also need to purchase this kit for $27
http://www.brweldingsupplies.com/bra...ct_id=315&ID=1
A reasonable Option:
A Tweco Flexi-MIG Conductor Tube might make it possible. If you reduce the bend in the conductor tube it should help reduce birdsnesting at the feeder spool.
I wrote a much longer post but the forum had a hickup when I posted.
http://news.thomasnet.com/companystory/517294
Here's another conductor tube with less bend:
http://www.airgas.com/browse/product...&WT.svl=109536:
Here's another flexible tube:
https://www.mythermadyne.com/thc/en/...2508false%2508Last edited by Johnny; 02-02-2009, 08:05 AM.MillerMatic 140 Auto-Set
Originally posted by handyman52607 View Postall i have are basic fabricater tools: torches, chop saw, grinder, and of course the miller 135. i would'nt be doing anything major, just repairs and some small scale fabricating. welds no more than one inch long, if that.
Well I too had tried it back when I had a 135. If I pre-heated I could get an OK weld on 1/8" but man that was the limit. On much thinner then that there just wasnt much control, especially for doing a repair job where the thickness might not be known. I used the teflon liner from Miller, never had an issue with jamming."Better Metalworking Through Research"
Miller Spot Welder
Here's another potential and mucch less expensive option. I am not a welder but I can problem solve just a little bit.
We all know that birdsnesting makes it darn near impossible to use a regular mig gun with aluminum even with a brand NEW liner and straightend out hose. The birdnest happens at the feeder but is caused, mainly I believe, at the bend in the conductor tube. If you can reduce the angle of bend in that tube the wire will hang LESS at the feed rollers.
It wouldn't be perfect but certainly better. The Miller Spoolmate option is expensive enough to make you give up completely or buy another welder. Getting or fabricating a more straight conductor tube might be reasonable option.
http://news.thomasnet.com/companystory/517294MillerMatic 140 Auto-Set
Tweco Flexi-MIG Conductor Tube might make it possible. If you reduce the bendin the conductor tube it should help reduce birdsnesting at the feeder spool.
The MM 135 and MM140 have the same power rating and I have a 140AutoSet.
This is 1/16" wall square tubing and 1/8" flat bar. It looks welded OK to me.
http://oregonian.biz/funfun/Welding/5.80/IMG_6034.JPGMillerMatic 140 Auto-Set
Welding aluminum with MM135
I came on here a while back and asked the same question about the MM175. With the help of some good people here I found out you can. I bought a new Teflon liner and never installed it. It feeds just fine with the standard liner,(A new one). It took me a while to get the machine set up, because I was not experienced with MIG. Once you get things set, just practice a lot. It will work.MM175
PrecisionTig 185
Lincoln AC Tombstone
Century fluxcore
Victor OA
Originally posted by Johnny View PostThe MM 135 and MM140 have the same power rating and I have a 140AutoSet.
http://oregonian.biz/funfun/Welding/5.80/IMG_6034.JPG"Better Metalworking Through Research"
Miller Spot Welder
spoolmate 100 on millermatic 135
Serial# is LC175022 and above ( with the 2 pin square drive motor plugs)
the switch plugs into the harness . If it is a lower serial number , you have to do some wiring , but not hard to do . Go to :
http://www.brweldingsupplies.com/pro...roduct_id=1096
