tungsten type and tip profile for AL welding
  • tungsten type and tip profile for AL welding
    I've owned a TIG welder for a couple of years, and am proficient on mild steel and stainless.
    My aluminum welding and out of position welding need some help, so I have been in a welding class for the last couple of weeks at the local college.
    I started doing some aluminum today after spending a couple of weeks on vertical and over head steel.
    The instructor started me with a pure tungsten electrode after balling it on AC a bit.
    He stated that he uses Thoriated (red) tungsten when he welds aluminum in his home shop.
    I also tried some Lanthanated (blue) with a short taper ground on the tip when welding some of the aluminum coupons and it seemed to give me a tigher arc and bead profile than the pure.
    I was welding 1/8" plate, butt, lap, T, and outside corners.
    I'd appreciate additional opinions on tungsten type and tip configuration when welding aluminum.
    thanks,
    Mark
    That depends!
    An inverter type TIG will want a pointed tungsten -- the old style NON inverter welder will need a balled end.
    Funny -- it took me about a year to find that out... but if you read the fine print on Millers (or the red one) sales info - you'll note the difference for SquareWave machines vs Inverter versions.
    Yes - Weld is my last name
    2000 sq ft home shop
    Miller 210
    Optrell Satellite AD Helmet
    Thermal Dynamics plasma
    12" Cold Cut saw
    Jet Mill/Drill
    Wilton Vert Band saw
    Too many hand tools to count
    Too much time on my hands
    Too many friends that need something done
    Having tools doesn't
    mean you have skills
      I use 2% Ceriated ground almost to a point with a small flat spot left on the tip for AC on squarewave machine all the time. It will get a small half ball on the the tip after a few minutes, but never gets very big. You don't need a lot of cleaning action running tungsten this way. Both squarewave and inverter machines can use pretty much any tungsten to weld aluminum. 1% Zirconiated is a great AC only tungsten.
      Oh yeah, don't grind a pure tungsten to a point.
      Dynasty 200 DX runner
      Sync 350 LX
      XMT 300 w/D74 and roughnecks
      Hobart 135
      ESAB PowerCut 875 plasma
        search this site for threads on tig welding. this has been beaten to death several times and will provide a wealth of information faster.
