Along with the regular sharpies. The metallic sharpies, (silver) have aluminum powder in them takes longer to burn off. Gold has (brass) but may contaminate the base metal more.
Starting on the left side
1 Aluminum flat replacement for soap stones LWS, Tractor Supply
2 A correction pen can be used as the materials in them make for good silver solder stop flow.
3 Aluminum pencils sold by the LWS as a metal high temp marking pencil. This is an artist metallic coloring pencil, that you can buy at ant art supply a lot cheaper than the LWS. One I have seen 4 times the price.
4 Flat soap stone in holder LWS
5 Round aluminum high temp marking lead in a mechanical pencil. Tractor supply and LWS. Again contains aluminum powder in a binder.
6 Round soap stone/holder LWS
7 & 8 are the spring loaded punches when it absolutely has to remain nothing works like punch marks following a line and filled with chalk. As you work the chalk dust can be reapplied, and the punch mark will last till the metal is raised to a fluid state.
9,10,11 are plain old chalk lighter colors on dark metals darker chalk on light metal. If you want it also works well on the cement floor or welding table top for layout. To make it a little more permanent, you can spray it with cheap hair spray. which is plastic spray just remember it does flare some depending on the brand.
You can also get true carbon or graphite pencils at the art supply they will stop the silver solder and can be used as anti flux. Also they will stay around to a higher temperature. You want a #1 pencil (softest)
Originally posted by Aerometalworker
As to problems with sharpies
1 Always store with the tip pointing down pen in the upright position.
2 You can wipe the tip with an alcohol based wipe, used for cleaning the area for injections or sticking something up with a self glue pad.
3 Never use them on oily or greasy material as that will clog up the porous tip and no amount of cleaning will help.
4 the biggest problem with sharpies drying out, is the cap not being snapped back on till it clicks. And drys out (tip).
5 to try to bring back the dried out sharpie clean or even dip the tip in alcohol quickly wipe off and see if it will work.\
