MM200 Input Voltage Taps
  • MM200 Input Voltage Taps
    Hello,
    I just picked up a MM200 and want to set up the input voltage for 230V.
    However the Owners Manual says: Compare the position of the jumper links on the input terminal board to the voltage link arrangement shown on the voltage input label.
    I have no label. I think it fell off.
    Anyone have a picture of the label?
    Or, know the correct taps for 230V?
    Thanks,
    Gif
    MM200
    Mm 200
    jeepgif: Is it possible that you have a 230V model, and don't need to be concerned?
    Just a thought why there may be no label.
    Dave
    "Bonne journe'e mes amis"
      ok, then why the two taps and jumper?
      Thanks,
      Gif
      MM200
        Have you tried to use this place.
        http://www.millerwelds.com/service/ownersmanuals.php
        Page 38 of the manual, circuit diagram number SB-119 327-A
        The red arrow is the volt select.
        It looks like it is set to 230 volt
        Be safe
        Jeff
        Give more than you get and
        you will get more than ya need.
        This is true for the good and bad
        that life puts out.
          Thanks,
          Gif
          Gif,
          Welcome to the forum.
          I'm guessing you have a 1981 model MM200. Serial # should start with JB.
          You probably have a 200/230v or 230/460v input. Look on the face plate. If you have a 230/460v input, you really can't go wrong connecting it to a 230v source. You'll know when you have the jumper set to 460v. The fan will barely turn on when you power it up.
          Jumper settings are in the center of the very first pic. Kind of red color and three brass screws and nuts.
          Jumper settings:
          200/230v input:
          200v = jumper left and middle
          230v = jumper middle and right
          230/460v input:
          230v = jumper left and middle
          460v = jumper middle and right
          It is common for the paper label in power input to fall off.
          PM me your address and I'll email you a manual.
          Charles
          Millermatic Passport Plus
          Millermatic 350P with Python
          XMT 304 /w S-64 feeder and 12VS
          Dynasty 300 DX
          Thermal Arc 400 MST
          Premier Power Welder for my trail junk.
            [ATTACH]16800[/ATTACH]
            Thanks,
            I do have a copy of the PDF. That is where I got the instructions I referred to in my first post.
            How did you conclude that mine was set up for 230v from the circuit diagram number SB-119 327-A? I do not see a connector identifier called out.
            Thanks,
            Gif
            MM200
              Originally posted by crawler View Post
              Gif,
              Jumper settings:
              200/230v input:
              230/460v input:
              Charles
              Yes, mine is rated for 200/230 input voltage as marked on the front.
              So I should be all set as is. (230v = jumper middle and right)
              Thanks,
              Gif
              Edit: SER # HK343965
              Found the settings in the "older" model Manual.
              MM200
                Thanks,
                Gif
                Gif,
                Your settings are correct. Let me know how it welds. Those old MM200 welders had industrial feeder size feed motors. Very heavy duty.
                Your welder must be one of the very first MM200 made. 1979 model.
                Charles
                Dynasty 300 DX
                Thermal Arc 400 MST
                  A very clean looking machine .
                  for being that old
                  They were a sweet welding machine.
                  Good luck with her
                  Rich
                  Love the power of Blue
                  Sync 200
                  Lots of Tools!
                    Gif,
                    Charles
                    It might be old, but it is in great shape!
                    Wish I could say the same for me.... (round is a shape; right!?)
                    I burned some 1/4 plate, exhaust scrap, and some 5/8 plate I had lying around. So far so good.
                    I am used to a MM35, so this machine feels familiar. However I can tell the power difference in this machine. It has a much deeper tone on the heavier stuff.
                    MM200
                      My buddy just picked up this MM35s. Works great.
                      MM200
                        nice looking machine
                        -i thought my 1981 millermatic 200 was the only one around in mint condition.
                        your machine looks every bit as good as mine
