Lincoln Weld Pak 100
  • Lincoln Weld Pak 100
    I've got a buddy thats gonna let me have one of these for $75 but it's not set-up for gas yet . Does anyone know what all the kit consist of to put gas on it and can I possibly buy the individual pieces as I already have a regulator and gas hose etc. ? I've seen the kits on flea bay for around $120 but hate to pay for stuff I already have .
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Powcon 300st
    Lincoln Weld-Pac 100 ??
    Showdog, Hi;
    I DO NOT Think the Kit contains the Regulator or Hose,
    As far as I know it would be the internal Gas Solinoid(spelling)
    and not what you already have !!
    ................ Norm :
      weldpack 100
      look at homedepo kit has all you need but the tank $100.oo. good luck I love mine.
        http://www.mylincolnelectric.com/Cat...et.aspx?p=7115
        The Kit does come with the Reg, liner etc.
        Lincoln probably has the Solenoid as a part - give them a call.
        Probably just easier to buy the Kit though.
        Ed Conley
        MM252
        MM211
        Passport Plus w/Spool Gun
        TA185
        Miller 125c Plasma 120v
        O/A set
        SO 2020 Bender
        You can call me Bacchus
          Buy the kit, buy it online, or through a Lincoln warranty repair center, not from a distributor.
            K610-1 MIG Conversion Kit
            www.weldingsupply.com has them for $120.00, maybe one could be found cheaper? Comes with the solenoid and the rest of the needed parts.
            Dave
            "Bonne journe'e mes amis"
              ok, I actually have a WP100 with the conversion.... the kit comes with the gas hose (solenoid to whip socket), gas solenoid, tank hose, regulator (NOT a ball type flowmeter), and if memory serves, a small wiring harness.
              oh yeah, and the gas nozzle for the gun....
              Bobcat 225NT
              Cutmaster 52
              Lincoln Weld-Pak 100 buzz box
              Caterpillar TH63
              '07 Kawasaki ZZR600
                WP 100 Kit !
                Originally posted by nfinch86 View Post
                Showdog, Hi;
                Showdog, Sorry Man, I Was Wrong !!
                ........ Norm :
                  The regulator which came with the kit for my Weldpac 100 only had a gauge for the tank pressure. There was no gauge to show flow and no adjustment for that matter. I replaced it with a good flow meter (floating ball type) with adjustable flow and even though I no longer have a Weldpac 100 I still use the flow meter that I originally purchased to replace that one. I did pass the single gauge, fixed flow regulator on to the purchaser of the Weldpac 100. I did consider that regulator good backup, in case something happened to my flow meter though.
                  Larry
                  "I feel for the man who can only spell a word one way"......Mark Twain
                  Lincoln AC225-S (OLD/Copper Wound)
                  Lincoln Weldpac 100
                  Miller Matic 180 (auto set)
                  Miller Spool gun 100
                  Miller Spectrum 375 Extreme
                  Victor Super Range II
