Help Tig 350xl Wireing
  • Help Tig 350xl Wireing
    I bought a used Miller Syncrowave 350 LX , but I'm lost with the wireing??? I need to wire the garage and get it hooked up. Is this right??
    In my garage I need a 125amp 2-pole 240volt breaker (will this work, to run the system)
    Thank you for any help with this.
    Yes,
    you need at least a 125Amp breaker if wiring for 230-240 Volt input. A 150 is normally used if using the machine up to it's intended capacity.
    The input wiring specs are located in the owners manual that you can get online here.
    http://www.millerwelds.com/om/o356z_mil.pdf
    Page 18-19
    Make sure you use the correct wire size as well.
    Good luck
    Andy
      Thanks, I put a 150amp braker on the lead coming out the the garage. So I guess I'm covered. Thanks agian
