Hello all, I am writing this in hopes of some sort of resolution...
Several years ago, I purchased a brand new Synchrowave 180SD from Airgas in Flint, Michigan for 1500 of my hard-earned dollars. ( the one that does not have any other controls on it than heat. It took me 2 years to save for this welder. I use it appx 2-10 times per year, sometimes more. The work seems to come in spurts, but when it comes, I need the welder to work. After using it 2 times, I sent it in for warranty work via Airgas due to no HF start. They sent it to Saginaw for the warranty work. After waiting a month and a half I got it back. They said there was a known issue with a capacitor in the HF start circuit. OK no biggie, that sucks, but its fixed now, life goes on. Its 6 months later, I have appx 3 jobs on it since repair, still under warranty, and no HF start again. Sent it in again, waited again, and fixed again. Ok maybe 2nd time is a charm. They said they replaced a circuitboard. So time goes on, and again no HF start. This time I let them have it a little bit. They said they talked to their Miller rep, and next time it does it , they would give me a new unit. Ok that sounds like a good deal. Since then I moved to a new house, picked the house up, put a basement under it, so a great deal of time has passed. Welder is no longer under warranty. Done a few odd jobs with it in the last year or so, intermittent HF start, but I need it to supplement my income, so I have been living with it. Welded a snowmobile tunnel a couple of weeks ago for a guy, and it worked, but took a little time to get the arc to start. Went out last night to weld another tunnel, and intermittent HF start problem is worse, extreme pitting, and I cant seem to control the heat, when I try to give it just a little heat to clean the AL, the arc is wandering out of control, too much power, and sounds/acts/looks like there is no wave shaping whatsoever (raw AC, is that even possible)? Input power is good, using argon and green tungsten, 15-20 CF, the aluminum is clean, was using tried it at 70A, as well as 130. It was very cold in my garage, but I pre-heated the AL. Since it was making this guys tunnel worse, I got a couple of test pieces and moved to the bench, and tried a butt weld on those, and it was turning them into blobs of garbage. The pedal is working, but I cant seem to keep it running with a low amount of current for cleaning (either too little or too much). So after I couldnt weld 2 pieces together on my bench, I pulled it out of the cart, set it on the floor of my garage, told my customer I couldnt help them, again, and I'm thinking of sending it in for repair, again. This time I'll have to pay for the repair. After this repair, Synchrowave 180 SD go bye bye. I cant keep turning work away. I dont know what to do, but I need a welder that works. I'm sure I'll get some replies to this questioning my abilities/procedures, but rest assured, I know how to weld.
