GMAW when to push or pull?
  • GMAW when to push or pull?
    Just curious on some input.
    When mig welding, when would it be appropriate to use a push technique as oppose to a pull technique and vise versa?
    Thanks guys.
    Regards.
    Please don't take this the wrong way, I don't mean to be rude. (Rough day at the "office")
    Knowing when to push and pull is something that comes from experience. It's all about seeing, interpereting and understanding what the puddle wants to get the desired effect. Practice and try different angles, see what you get. That is really the best way.
    Some general guidelines:
    -Push= smoother flatter bead with less penetration. Usually a little higher travel speed.
    -Pull= Taller more peaked bead with greater penetration and more build up. Usually a little slower travel spee.
    Of course, since the angle is infinitely variable, it's up to you the welder how much or which traits you want.
    Practice, practice, practice.
    Dynasty 200DX, first generation
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    Whole bunch of hand/air tools.
    and a wish list a mile long
      Very well put shorerider.
      Be safe
      Jeff
      Give more than you get and
      you will get more than ya need.
      This is true for the good and bad
      that life puts out.
        Another angle to look at:
        Push = more heat, more "dig" into the parent metal
        Pull= Less heat put directly into the weld
        If you are welding heavier plate (3/16"plus) or lots of fillet welds, you may have better results by pushing.
        For light guage steel (especially butt welds) you may find that pulling the puddle will work better-- you stand a little less chance of burning through the thin stuff.
        As for the actual angles, there is no substitute for experience. Practice practice practice!!
        Big Blue 400D
        Trailblazer 302
        Miller S-32 suitcase
        12VS suitcase
        Lincoln LN-7 (BIG suitcase)
        Victor torches
        Lincoln 350MP with 35' push-pull gun
        Lincoln PrecisionTIG 375
        Spectrum 1000 plasma cutter
          Generally.....
          Push on the thin stuff, pull on the thick.
          Big 40 Deluxe
          12RC
          WC-24
          30A
          Dynasty 700
          XMT 456
          Custom Cart w/the following:
          S-74DX
          Optima Pulser
          Coolmate 3
          XR Control Box
          XR Alumna Pro Python W/C
          CP 302 w/22A
          MM210
          Synchrowave 180 SD
          Spectrum 2050
          TB 302
          12RC
          WC-24
          30A
          HF 251 D1
          Dynasty 200 Coming Soon
            Now the last 2 posts say the exact opposite. I wasnt getting the hang of using a wire so I bought a stick.
            Who do you call when the lawmakers ignore the law?
            Miller AC/DC Thunderbolt 225
            Miller 180 w/Autoset
            Old cutting torch on LPG
              Sorry to say it but you've got it backwards.
              Makita 5" grinder
              IR SS5L compressor
                Well........this is really clear......
                I'd also like to know which is which..............Thanks
                RoyB
                Dartmouth, MA
                http://www.rvbprecision.com
                Millermatic 185 MIG
                Miller Diversion 165
                Purox W200 O/A
                Grizzly 9957 Mill
                Grizzly 4030 Metal Band Saw
                Grizzly 1050 Knife Belt Sander
                Jet 1236 Metal Lathe
                TP Blast Cabinet
                  You can't be serious? Try it for yourself. Heck you cannot believe anything on the internet.
                  That said my experience is a tad different. I say always push when possible. If the material is thick then I turn up the heat. When there are times because of positioning etc. that it isn't practical to push then I re-adjust the heat and do whatever I must to weld.
                  I've worked with a few guys who always pulled and I must say they had more quality problems than most other people.
                  I worked at one place where we had to push vertical down on aluminum and I never could feel really comfortable with that and usually kept perpendicular.
                  Your mileage WILL vary and make you the unique craftsman you are
                  Miller 30-A Spoolgun
                  Miller WC-115-A
                  Miller Spectrum 300
                    See....That's what I'm talking about.
                    I've always pushed on all my welding. The very few times that I had to pull, because of position, the welds were not as nice. If I wasn't getting the results I expected, I adjusted the heat.
                    I think this comes from many years of O/A welding.
                    RoyB
                    Dartmouth, MA
                    Millermatic 185 MIG
                    Purox W200 O/A
                    Grizzly 9957 Mill
                    TP Blast Cabinet
                      Classic thread.
                      Weekend wannab racer with some welders.
                        I think it just comes from the instincts of being a good welder with some exp.
                        The point I was making is my exp is different from some but the internet isn't all that great of a place for answers simply because you hear every kind of answer there is. I hope you don't feel I was picking on you either btw. I am a true hypocrite as far as that is concerned
                        Not sure if you have any specified welding codes or whatever that specifies this push or pull question.
                        To me it is sorta like pushing the electrode when stick welding...it ain't normal but sometimes you gotta do it. (not talking about uphill but flat etc.)
                        I am sure there is somebody who will chime in and enlighten us tho.
                        Miller WC-115-A
                        Miller Spectrum 300
                          You are correct in that it is all about experience, knowing what you're looking at through your lens, and how to correctly manipulate what you see into what you want and what you need.
                          I have pushed SMAW, pulled GMAW on aluminum, fed filler behind the torch in GTAW, and so on.
                          Sometimes you just have to do it. There is no other option. I know that. That should be stressed a lot more to any new welder.
                          That said, I will explain it how it was explained to me at Caterpillar. I haven't seen anything to discredit what I was told, but I do not hold it as the end all/be all of the push pull argument either. It works for me, and that's all I really care about. What works for me, may or may not work for any of you.
                          GENERALLY, when you push, travel speed is increased. As such, your arc tends to run up in the front 1/3 of the puddle. This results in shallower penetration, and a wider, flatter bead. It also inputs less heat into the base material, which is important when welding on thin material/sheetmetal.
                          GENERALLY, when you pull, travel speed is reduced. As such, your arc tends to run in the middle to the rear 1/3 of the puddle. Since there is more molten metal from the puddle out ahead of your arc, it slightly preheats the base material resulting in deeper penetration. Bead profile is deeper, narrower, and more pronounced.
                          Anyway, that's how it was explained to me. It won't hurt my feelings either if you don't believe it. It is after all, a generalization.
                          Big 40 Deluxe
                          12RC
                          WC-24
                          30A
                          Dynasty 700
                          XMT 456
                          S-74DX
                          Optima Pulser
                          Coolmate 3
                          XR Control Box
                          CP 302 w/22A
                          MM210
                          Synchrowave 180 SD
                          Spectrum 2050
                          TB 302
                          12RC
                          WC-24
                          30A
                          HF 251 D1
                            Here's how it works.
                            Push on the thinner material to prevent burn through.
                            Pull to get deeper penetration. These are at a given weld parameter.
                            Because the gun angle during a "push" is always directed at the unwelded, cooler basemetal, the weld will have less penetration.
                            When in a "pull", the gun is directed at the weld puddle that is already hot and therefore the added weld time directed at the hot puddle gives deeper penetration.
                            This info and cross section pics are available in our GMAW weld book.
                            Have fun!
                            Andy
                              Have fun!
                              Andy
                              Sounds familiar.....
                              Big 40 Deluxe
                              12RC
                              WC-24
                              30A
                              Dynasty 700
                              XMT 456
                              S-74DX
                              Optima Pulser
                              Coolmate 3
                              XR Control Box
                              CP 302 w/22A
                              MM210
                              Synchrowave 180 SD
                              Spectrum 2050
                              TB 302
                              12RC
                              WC-24
                              30A
                              HF 251 D1
