There are seven basic tools that just about everything mechanical use in one form or the other to function. Before you run to web see if you can remember. I'm sure there are 7 but I can't remember all of them.
OT ....do you know"
OT ....do you know"
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
and check out some of my ironwork and other stuffTags: None
Originally posted by monte55 View PostThere are seven basic tools that just about everything mechanical use in one form or the other to function. Before you run to web see if you can remember. I'm sure there are 7 but I can't remember all of them.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
Well, I'll have to dispute even six, because the wedge and screw are both inclined planes.
And I dispute the technical three (inclined plane, lever, and wheel) to include the pulley, which some classify as wheel and axle. But a wheel and axle gives no mechanical advantage other than friction reduction (using a barrow instead of dragging a load), conversion of force (barrow wheel rotating as load is moved linearly), while a pulley (compound, block & tackle) reduces linear effort.
I have to agree. Even the standard toothed gear engaged with another is wheel and axle and lever.Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
As commonly defined, the 6 basic machines are:
Screw
Inclined plane
Lever
Wedge
Wheel and axle
Pulley
And no, I didn't know this off the top of my head. I had to look it up. Here is one source..... http://www.fi.edu/qa97/spotlight3/spotlight3.htmlJim
