3 phase power
  • 3 phase power
    looking to run a delta welder 450 3 phase using
    a roto phase i do not have 3 phase
    does any one know how the welder will work
    i am aware of the size unit needed
    I would imagine it would work just fine... I just can't see how you're going to save any money using this delta welder... rotary phase converters aren't cheap... did I mention they're LOUD...
    A couple of years ago we put up a building that had a phase converter for their test lab (50HZ for the stuff headed to europe)... The things sound like a siren that NEVER shuts off!
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
      phase converter
      we have a 15 hp phase conveter now its not loud it sounds like a motor running
      i want the delta for its power and duty rating 400 amp mig
      we only have single phase .no single phase welder does that
      the electric co wants a small fortune for 3 phase around 30 k
      i was told a 50 hp roto phase would work
      thanks jeff c
        If your phase converter is making anything other than smooth motor whirring sounds (with the exception of the couple seconds after you add an unbalanced load to it), there's something wrong with the converter's wiring, components (balance caps), or the motor's bearings are probably dry or toast.
        Syncrowave 250DX
        Invison 354MP
        XR Control and 30A
        Airco MED20 feeder
        Thermal Dynamics Cutmaster 81
        Smith O/A rig
          the one I was talking about was a couple hundred horsepower..... I've never seen an electric motor over 50HP that I'd call quiet....
          Bobcat 225NT
          Cutmaster 52
          Caterpillar TH63
          '07 Kawasaki ZZR600
            A couple hundred horsepower phase converter? For the price of the motor, that 30K install bill would be cheap...
            Got any pics? I'd love to see the start cap array for that.
            Syncrowave 250DX
            Invison 354MP
            XR Control and 30A
            Airco MED20 feeder
            Smith O/A rig
              well... it wasn't actually a phase convertor... it was a rotary frequency convertor, custom designed by them with a 3ph 3000rpm motor to give them the 50hz 3ph they needed to test their european product... same basic idea, just wired a little different....
              Bobcat 225NT
              Cutmaster 52
              Caterpillar TH63
              '07 Kawasaki ZZR600
                Not sure if it would work on a welder but I use a variable frequency drive [vfd] to run my three phase vertical milling machine on single phase power . Vfd's work very well for my application with the mill as the don't have any of the negatives of a phase converter .
                Bernard 3500ss water-cooler
                Rockwell vertical mill
                Beverly Shear B-3
                Beverly Shear JR
                Home-made English wheel
                Milwaukee Porta-band
                " Sawz-all
                Tennsmith 36" stomp shear
                Powcon 300st
                  I don't know if a VFD would care for the spikes every time you strike an arc...
                  Miller DialArc 250
                  Lincoln PrecisionTig 275
                  Hypertherm 900 plasma cutter
                  Jet 14 X 40 lathe...ditto
                  Logan 7" shaper
                  Ellis 3000 band saw
                  Lots of dust bunnies
