200dx
    Originally posted by tsutt View Post
    KB&FATFAB, Tungsten IS the ticket. Worked like a champ, flawless.
    Thanks
    Todd
    Dynasty 350DX
    Dynasty 200DX TigRunner
    MM 350P
    MM Passport Plus
    Spectrum 375 Extreme
    08' Trailblazer 302
      Thanks
      Todd
      Todd,
      CONGRATS!!!!!!!!!! and a BIG thank you for trying it out and letting us know!!!!!!!!!!!!!!!!!!!!!! (Inquiring minds want to know!!!)
      that's why I love this forum
      I'm not late...
      I'm just on Hawaiian Time
        Thanks
        Todd
        Thanks for the recognition, vary glad to have had a part in helping.
        I went through the same issues. I have used both cerated and lanthanted(sp??) I end up prefering the lanthanated(sp).
        It "feels" like it holds up better.
        any thoughts about this???
        Yes I hijacked this thread lol
        FB
          With our 350 Dynasty here with exactly the same problem we still haven't found a solution. We've tried all the different electrode types, had a new HF board fitted and it's still doing it.
          Sometimes when it's doing it, if you touch the filler wire to the work surface and pull it away the arc will light off but it won't do it all the time and you end up with the world's most expensive scratch start Tig machine.
          In the new year we will be insisting on the LWS to supply us with another Dynasty 350 so we can at least compare the 2 and see if it's an inherent problem with the Dynasty 350's.
          Regards Andrew from Oz.
          We are tig welders, gravity doesn't worry us.
          Miller Dynasty 350 Tig.
          OTC AVP300 AC/DC 300 amp hybrid wave Tig. (now retired)
          Kemppi MLS 2300 230amp AC/DC Tig for home with all the bells and whistles.
            I"m sure you will let us know as soon as you figure out how to get it fixed!
            Hope it's not something with all of them!!!!!!!!!!!
            thanks,
            bert
            I'm not late...
            • #21
              I have been reading this board for several years and the HF problems on the 200DX and been mentioned many times. At one time Miller even admitted there was a run of 200dx's that had defective HF boards. However I wonder if there was more to it than bad boards, maybe more like poor design? What make me think this is the new Blue Lightning HF starting system that Miller just introduced for the Dynasty 200 series machines.
              http://www.millerwelds.com/about/new...ticles248.html
              Like any manufacturer they eventually update their product and call it an improvment while it might really be a correcting a defect. Since I am involved in the maintenance field I have worked with 10 to 20 pieces of identical equipment from the same manufacturer I have some insight. If there is a design flaw it repeats it self over and over. Before long I am repairing the same problems day after day as each piece of equipment fails. The ONE difference here in my experience with manufacturers is that Miller will step up to the plate and take care of their customers when problems occur.
              Miller Dynasty 300
              Millermatic 252 / 15 A Spool Gun
              Hypertherm Powermax 85
              Passport Plus Spoolmate 100
              • #22
                FB
                I found that the arc wandered when I used ceriated tungsten. I checked with Miller's "ask the expert" and they said that this was because ceriated tungsten was prone to axial splitting of the tungsten. They suggested only sharpening the tungsten 50% of the diameter. I didn't like this suggestion because I usually prefer a sharper tungsten with a 1/64 " flat to get good penetration. Since that time I have used the diamond ground tri mix tungsten and have never had the arc wandering problem. I have never used the lanthanated tungsten but many on this web use it and swear by it.
                Smith Oxyacetylene Torch
                Miller Dynasty 200DX
                Lincoln SP-250 MIG Welder
                Lincoln LE 31 MP
                Lincoln 210 MP
                Clausing/Colchester 15" Lathe
                16" DoAll Saw
                15" Drill Press
                20 Ton Arbor Press
                Bridgeport
                • #23
                  As far as that run of bad 200dx's??? Is there a list of serial numbers that shows which ones were possibly bad????
                  thanks,
                  bert
                  I'm not late...
                  • #24
                    There aren't any service memos on the 200DX, therefore no bad run of them as far as the files go other than a better shoulder strap.
