Pics of bent steel (Cert Test)
  • Pics of bent steel (Cert Test)
    ok here they are for all to view,
    The good ones look good. It's good they let you redo that one.
    EDIT: props for showing the bust
    hre
      this company does a double or nothing if you fail it the first time
      you have to do two of the same weldments and it just had to be Vertical down
      which isn't welding its caulking, i got some porosity in the first one, welded the other two ground them smooth gouged the back grinded it smooth welded them ground some more marked cut PRAYED AND PRAYED AND PRAYED some more then bent them and clean as a whistle then the Weld Tech said ill be ****ed you are a Weldor lol
      but hey if we can't show and even acknowledge our mistakes we can't learn from them and neither can others
        x2.
        Thanks from me too. What's the difference between a 'defect' and a 'discontinuity'?
        Craig
        RETIRED desk jockey.
        Miller Syncrowave 250.
          Good deal!!! I agree with the others, many people never mention their failures let alone show the proof.
          First bend test plates I ever did I failed the first try on the flat coupon, I was "looking past it" so to speak. I never failed one when I was practicing so come test time I was probably thinking about what not to do on the other tests instead of paying attention!!!
          at home:
          2008 Suitcase 12RC
          Spoolmatic 30A
          WC-24
          2009 Dynasty 200DX
          2000 XMT 304
          Sold:MM130XP
          Sold:MM 251
          Sold:CST 280
          at work:
          Invision 350MP
          Dynasty 350
          Millermatic 350P
            discontinuity and defects
            ok this can get a bit touchy depending who you talk to
            Discontinuity=Is the appearance of a in the weld of a weldment, However a discontinuity is not necessarily a defect, anything under 1/8inch, Tungsten Inclusion, unburnt Consumable insert (P.S. do not use ur ******* file as a Consumable Insert xray techs will see it lol not my experience but one of my apprentices did it two years ago on a test piece) Have it hanging in my office).
            Defect= is exactly as it sounds is a break,Porosity, Inculsion over 1/8inch,
            just to name a few examples.
            ^on this above if it is under 1/8th of an inch it is a discontinuity, over 1/8th a defect.
            (but it is enough for the X-ray ech to say grind it out and redo it) and your supervisor to chew you out.
              Hey Mooseman:
              Where you at, down by Kennett? The Cape? I grew up in St. Louie as a kid, left in '71. The caverns are cool, and the test coupons look good, thanks for all the info. I'm making a bunch of 5" sch 40 coupons from a 6' piece I bought for $40 at the scrap yard Monday. I know it's a little thin, but gotta stay in practice! Gotta go do some cutting and grinding
              "Bonne journe'e mes amis"
                prep
                i prepped my own and i know i gouged a couple of them
                i live between kennett and cape lol i live in malden and im from bloomfield
                but what made you say that about prepping my coupons
                  A discontinuity is any abnormality in a weld, discontinuities can be acceptable.
                  A defect is an abnormality or abnormalities that because of it's size, or the number of them, or it's type, are not acceptable. A defect means a rejectable weld.
                  JTMcC.
                    Originally posted by Iron Head
                    Some things are hard to tell after being bent, but you should never grind / sand perpendicular to the length of the coupon
                    i know that but when your using a sand buffing wheel that only moves one direction and it sands the same no matter how you turn it u kinda only have one option lol
                      Thanks for the answers.
                      Craig
                        JTMcC.
                        ^ shorter version lol
                          certs
                          man im glad i go done with my cert test now my head is so stopped up i can't breathe
                            Sanding
                            Some things are hard to tell after being bent, but you should never grind / sand perpendicular to the length of the coupon!
                            I always grind down the weld perpendicular to the coupon until it's flush with the base metal. Switch to a # 36-grit sanding disc, do the whole coupon making sure to never sand perpendicular, always lengthwise! Then switch to # 80-grit, (or even higher) sanding disc. Then knock all the 90° corners off the coupons just a touch using the # 80-grit disc. Remember always grind / sand lengthwise!
                            If by any chance you get to bend your own coupons, take some soapstone cover the entire coupon with the soapstone, and the 3-rollers / round stock of the machine.
                            I was taught this by a CWI back when Christ was a corporal.
                            I totally agree with you on your sanding description.I can't believe how many people that try to metal finish their welding coupons or projects with a hard disc.
                              grinding
                              I agree with that method but that was the only way i had to get it done and i did not at all use a hard disc it was a soft sand buffer disc. but they still passed even with out proper grinding so the weldment is solid lol
