Wiring Question-220V.
  • Wiring Question-220V.
    Hi, I have a question about wiring? I bought a 220V. floor shop heater, which has an ajustable thermostat.
    The problem is when I don't want the heat on, I turn the thermostat down to Zero and the heat stops but not the Fan!! OK. My question is, can I put an inline switch in the heater cord, remembering that it's on 220V.??.......... Norm :
    I've never seen an inline cord switch rated for 230v or any significant amperage... is it hard wired?
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
      nfinch86- Canadian Weldor :
      Hi; No , it has a plug thats pluged into a 220V. receptical. I imagine the thermostat is supposed to shut it down? I turned OFF at night, when I opened the shop door in the morning, the darn thing was running?? So now I just unplug it from the receptical at night!! PS. IT'S really 240V.!! 220V.,- 240V. same thing I guess??
        Open up the fan and look at the wiring,it sounds like somebody bypassed a relay or it's stuck. The fan motor should kick out after a while. Sometimes the fan might run for a short while to cool it down.
          HI, and thanks for your answer. Now what do I look for?? ....... Norm :
            Instructions any insight as to the proper operating of the fan? Does it say anything about the fan being on all the time?
            Sounds like a new unit so I doubt anyone messed with the wiring inside.
            Ed Conley
            MM252
            MM211
            Passport Plus w/Spool Gun
            TA185
            Miller 125c Plasma 120v
            O/A set
            SO 2020 Bender
            You can call me Bacchus
              ED, Hi; Ya it's new maybe two weeks. As far as instrutions, I probably chucked-em. If I recall there was nothing specific other than ratate the numbered dial on the back.
              I'll have to check it this morning . Maybe I'm missing something?? Will get back to you!!........... Norm :
                Wire it through a outlet with a dedicated breaker, maybe?
                Miller Maxstar 200 DX
                Miller Syncrowave 180 SD
                Hitachi 4.5" grinder
                http://mhayesdesign.com
                  Thanks, It's on an outlet withv a dedicated breaker now, as ED said previously it's new.
                  I can't see there being a Wiring problem!
                  Maybe I didn't turn it fully off, I will Keep a closer eye on it!!
                  Thanks again for all the Ideas !!!!..... Norm :
                    Look for some sort of switch inline with the fan,there is no way the fan should keep running like that. If possible take a picture and post it up.
                      Check the TStat and make sure it doesn't have a small switch that is set on run and not on auto.
                        nfinch86-Canadian Weldor :
                        Woodshed, Hi; I don't Know what the TStat is ?? ... Norm :
                          Thermostat
                          Ed Conley
                          MM252
                          MM211
                          TA185
                          O/A set
                          SO 2020 Bender
                            Thermostat
                            OH, Now I get it??? Thanks I'll check it !!..... Norm :
