cylinder sizes
  • cylinder sizes
    Howdy all. I'm new to welding and looking at purchasing a MM180. I am trying to figure out what size cylinder in need to purchase for my shielding gas. I keep hearing about k, t, p(?) size cylinders and have no idea how large or small they are. Is there a chart or reference sheet out there that tells me how many cubic feet these cylinders will hold? Also, what size would be best suited for this machine? I will be welding mostly old farm equipment and small fabrication projects. Thank you for the help.
    It depends on how often you use it.
    This is an automotive discussion forum that has some great infromation
    www.autobodytoolmart.com/shoptalk
      Like metalmeltr said, It depends on how much you use it, maybe this link will help. http://www.airweld.net/images/Cylindersizechart.gif
      Miller Dialarc 250
      Miller Spectrum 625 X-treme
      Miller Bobcat 225
        You buy the biggest one that fits your needs. If i have to move them to the job often, i like 80CF, if i have to move them occasionally 125CF if i move them only for refill 330CF. The bigger the cylinder the less you pay per CF of refill. I pay 50 bucks for a 330 of argon and 37 for a 125.
        Millermatic 175
        Spectrum 375
        All kinds of Smith OA gear
          Around these parts a 125(the cubic feet it contains) is the biggest you can buy as your own. I use these for portable work. A 330 is the largest in compressed gas cylinders,and can only be leased. If you can buy A 330 from an individual or supplier get that or go with the 125.
          2- XMT's 350 cc/cv
          1- Blue star 185
          1- BOBCAT 250
          1- TRAILBLAZER 302
          1- MILLER DVI
          2- PASSPORT PLUS
          1- DYNASTY 200 DX
          1- DYNASTY 280 DX
          1- MAXSTAR 150 STL
          1- HF-251 BOX
          1- S-74D
          1- S-75DXA
          2- 12-RC SUITCASES
          1- 8-VS SUITCASE
          2- 30 A SPOOLGUNS
            Try an 80 cf size for around the house
            If you plan on doing small projects or practice in the backyard I would go with an 80 cu ft. size. This size has a screw on cap. Smaller cylinders don't have a cap except some 60 cu ft cylinders. 60 cu ft is not a common size or may not even be available from your store or area. Some welding stores won't sell you a cylinder larger than 80 cu ft size but most will sell up to 125 cu ft size. The two sizes are the same diameter, 125cu ft. is just taller. For household use renting a cylinder may cost you quite a bit more over the long run. A full 80 cu ft. cylinder will probably be about $210 to $230 to buy. A refill may run about $35 to $40. Make sure that the welding store that you buy the cylinder from is convenient. Other welding stores may or may not exchange the empty cylinder for a full one. Airgas tends to be higher priced than the independant dealers, but is nationwide. If you move out of the area then try to sell the cylinder back to the dealer. Keep the original bill or title to the cylinder so you can prove ownership.
            75% Argon/25% CO2 is common and allows easier welding on thin material. 100% CO2 can also be used for steel welding, but usually comes in older 330 cu ft size rental cylinders. Most of these have 50 pounds of CO2 in them. CO2 welding tends to be harsh and has a harder arc and more spatter.
            Some welding stores will not load ANY cylinders into the trunk of a car while others will allow a small shielding gas cylinder to be loaded but will not do it themselves. Sometimes their policies vary by the salesman!
              All my cylinders are purchased as refered to as "S" or 125cf of C25,Argon or "WS" or flat top for acetylene, original bottles were purchased from Linde yrs. ago at a dealer my wife worked at, since bought out by Airgas which those dudes are high on everthing. I now deal w/an independant. Latest bottle I've purchased is a CO² which was ~$235., personally I would not fool w/the tiny cyl. nor lease, I'm kinda in between a little work and a lot.
              Good luck
              L*S
                i used an 80 tank of C-25 for years. then some one pointed out to me that Co2 only causes splatter problems over 200amps. so i tried it and have used it exclusively ever sense. the Co2 tank is smaller than the 80 and lasts about 4X longer at 1/2 the price. so if its at all possible i recommend you try it out. and look into prices. biggest thing will be ask around about what sizes they will sell, and fill options.deafman has a good point about checking about possible loading issues.
                another thought to consider is Co2 is said to be more tolerant of less then clean surfaces. with farm equipment in the work load, it may be a +.
                having a tank of each would not be a bad thing. trust me when i say running out of gas in the middle of a weekend project is a real bummer.
                thanks for the help
                  Keep in mind you should be able to trade up your cylinder @ full value. Let's yoy start out for a few less bucks.
                  Dennis
                  Thermal Arc 185-TSW
                  Millermatic Challenger 172
                  VictorO/A
                  Atlas Craftsman 12 by 24 Lathe
                  Esab PCM-875
                  Wholesale Tool Mill-Drill
                    Tailshaft56 makes an excellent point. you could start out with an 80 and move up to a 125 if you feel the need for a larger tank. i have a 125 and an 80. i don't think any larger than that would be the easiest to move around, much less transport in a car. this may not be an issue, but might be worth thinking about.
                    thanks for the help
                      Thank you
                      Thanks for all of the great information. I have heard that buying a bigger bottle is cheeper in the long run since it cost less per cubic foot to refill. I will just have to figure out how much I will be using the welder and how often I will be moving it around. I know that I do not want to go any smaller than a 125cf cylinder but would like to go bigger if the LWS will sale me something larger. Also, I have heard that the cart that you can purchase from Miller will not carry anything larger than a 125cf cylinder. If I purchase a larger cylinder then I will have to make my own cart to handle it.
                        if you go with a tank bigger than a 125 you wont be building a welder cart, you will be building a tank cart with a shelf for a welder.
                        a 125 should be about the same burn time as a 11lb or 8" spool of wire. its nice to have a small spool of flux core on hand for windy days or must do dirty repairs, but best to stick with the larger spools for the solid wire. changing them out is not hard to do, but gets old with the lil 2lb spools.
                        be shore to show off the cart when you make it, its tradition.
                        thanks for the help
                          Thanks for the info. I did not know that a 125 would last about the same time as a 11# or 8" spool. I also found out today that one of the LWS would sell me a 250 or a 330 cylinder (customer own) but it would still have their name on the ring so only they could service it. About the cart, I think I am going to make a tank cart. I just have to figure out exactly how I'm going to design it. I have been looking for some ideas but have not seen a lot on my searches. I am debating about pneumatic tires on it so it will roll over most of the debri in the shop without getting caught on it. The only thing I worry about is the hot mettal melting them. Not sure yet what to do... any ideas?
                            I sorta feel like that part of the beauty of a 180 is the portability so you might want to consider that as well. The bottle is a hassle to move around steps and all that. An 80 sure packs nice. But I use 330s for about everything myself and little stuff for packin'
                            Miller 30-A Spoolgun
                            Miller WC-115-A
                            Miller Spectrum 300
                              i have pneumatic tires on my MIG and TIG cart, no problems so far, 7 years.
                              i also have the gas comp. on my owned tanks ring. he swoops them out just like any other tank. i can request a blank ring if i need it when i move, but for now i just rotate then without concern. he is the only one in my area that sells tanks over a size 80, so he is the only one that would fill them any way. so the name will only be an issue when i move ( not likely to happen) but for now its a swoop out, so no hydro tests for me.
                              thanks for the help
