Hey folks, I'm deciding between a Bobcat 250 and a Trailblazer 302 and have determined that either could meet my needs. Any input from current or past users beyond the obvious, as to choice, regarding reliability, maintainability engine selection and anything else you can determine. It's primary use will be a backup generator for the homestead with welding duties as a secondary consideration. I have all inverter machines now and either could run what I have. I'm also favoring gas over diesel and LP. Thoughts and experiences? My current starting load is roughly 8500 watts with a running draw of 6500.
Bobcat vs Trailblazer
Before we go further
Just to maintain focus, I eliminated many good machines from all manufacturers for reasons. The two named in my original message above are all that remain to be considered. FWIW, the other Red machines were eliminated for sound levels being higher than the other two above...yup they are significantly louder.
Have you checked out this page yet? http://www.millerwelds.com/products/...ctorguide.html
A very good side by side comparison.
I have a Trailblazer 302 with the 22hp Subaru,but I haven't ever worked it harder than it could take so I guess you could say I'm happy with it.
If max generator output is a concern you may want to step up to the 23hp Kohler and gain 500Watts. I also just noticed it's 1 db quieter than the Subaru engine. The Miller with the Subaru has the same db rating as the Lincoln 305G has, interesting.at home:
2008 Suitcase 12RC
Spoolmatic 30A
WC-24
2009 Dynasty 200DX
2000 XMT 304
Sold:MM130XP
Sold:MM 251
Sold:CST 280
at work:
Invision 350MP
Dynasty 350
Millermatic 350P
Yup...thanks
Yup, I've seen it. I have found Miller to have the best documentation available in a easy to retrieve manner. I have to hand it to them also that they "sell" their product rather than compare it to others. To me that says a lot about the company behind the scene. It's always good to show your strength rather than point out your competitors weakness, at least in my view.
Sound difference is unlikely as the Ranger 225GXT, or 250 is the same engine as the Bobcat, unless you get the Robin which is somewhat louder than the Kohler
Bobcats have a continuous 9.5K power, whilst the Rangers ( over 225) are continuous 10K
A Miller bobcat costs the same as a Lincoln 250GXT, and several hundred more than the 225GXT. The Lincoln definately has more perks than the Bobcat, as well as a 2 year extended warranty option.
But if my only choices were a Bobcat to a Trailblazer in a Farm application, the Bobcat would rule out, as you really don't need the extra perks that the TB302 has
And they compare there product to others, As others compare there product to theres.
It all comes down to Blue and red.
I fix them all, I just happen to recommend Lincoln as the Better engine drive, and Miller as the better Static machine for the most part.Last edited by cruizer; 10-30-2008, 12:46 PM.
Cruizer
Might I ask which engine and or fuel you see the fewest problems for? IE; would you reccomend one engine over another given the choices offered by Miller? Also, could you speak to the durability or ease of maintaining the gen-set itself other than the engine. Is the gen design more reliable in the TB302 vs the BC250? Durability issues with either?
Cruiser makes a good point, if welding isn't the priority then you are probably better off with the Bobcat over the Trailblazer. It's a simpler machine and a little more friendly on the wallet.at home:
2008 Suitcase 12RC
Spoolmatic 30A
WC-24
2009 Dynasty 200DX
2000 XMT 304
Sold:MM130XP
Sold:MM 251
Sold:CST 280
at work:
Invision 350MP
Dynasty 350
Millermatic 350P
Kohler is better than the Suburu for after warranty repairs, Haven't seen a Robin last more than 3000 hrs, where as several Kohlers I've seen exceeding 4300 hrs with no problems. The Kohler is an inexpensive rebuild, whilst the Robin is very expensive and usually the welder is tossed.
Mind you these are for engine drives that We've serviced all there life and have been running on 5-50 Synthetic since thier 50hr breakin.
As I mentioned the engines between the Rangers and Miller Gassers are identical
As for the generators on the Bobus and TB 302, very few problems other than the occassional board in the TB. The Bobus is somewhat more symplistic.
As for being quiter, the only reason I can think of is that Miller uses a foam blanket in some of there machines. I don't do alot of the farmer Bobus machines so I can't recall if it's in them or not. Sill same muffler, same engine, same decibel levelsLast edited by cruizer; 10-30-2008, 01:34 PM.
Great
I'll move Kohler up on my engine list. You're far from the first person to say good things about those motors. Back to the generator portion, is there any complications of design in eithers or would you say the electronics (ie:board) are the primary defining item of reliability?
C Wagner
Shopping locally, I've seen only a $400 to $500 dollar difference in the gas versions....guess I'm thinking that if reliability/maintainability is easier on one or the other that is a small margin at this price point. Then again, maybe I've got more money than sense. I must say I certainly expected my choices to be very different, I initially thought i'd be choosing between different companies but find myself choosing between two different animals in the same pen. Looks like I'll have to wait for some longtime users to chime in with the reality they've learned.
Well there really isn't any boards in a Bobcat to blow, just a small idle module.
So from a reliablility stand point the Bobus is the way to go, going by your 2 blue choices.
And avoid getting talked into the electric fuel pump. It's only for high altitudes, and it definately has a reliability issue, basically it just supplys fuel to the main mechanical pump in the right side head. Tends to lock off the fuel, then you have to bypass it to get your machine going again.
