I'm currently attending school to become a qualified welder and to advance myself as much as possible. I am working on my open root 3g vertical up and I seem to have a few problems. I was wondering if a few of the more expierienced welders would be able to maybe lend a few tips and what not on the techniques of the craft. I have completed preparing a good Groove angle and filing a nice flat land on my coupons. The first thing I'm struggling with is getting a nice solid tack with proper penetration and a good keyhole to work with. I'm getting a little better with this by toying around with arc length and oscillating a bit more to form a better puddle. But, I am still having some troubles with getting the first portion of the weld to penetrate properly. The second thing I'm struggling with is starting again from a place I have stopped. I have a good Work angle and Push angle and can run a good bead with solid penetration using the E6010 3/32. However when I stop to continue the weld I am having a bit of trouble tying the weld in. I have tried a few different ways such as grinding the previous weld about 3/8 back and making a downward slope very thin towards the keyhole and I've also tried widening the keyhole a bit and arcing in front of the weld then dragging it back. If I could get a few tips on how to tie in better and or some info on how to prep the previous weld a different way it would be greatly appreciated.
We are using a 3/8 to 5/8 mild steel plate usually with about a 37 1/2 Bevel angle and our land is generally prepped to 1/8.
We are also using the E6010 3/32 for the root followed by the E7018 for our Hot pass, Fill Pass, and our Cap.
So ya any good advice on how to better myself would def be appreciated and ty for taking the time to read my post.
