What process is it?
  • What process is it?
    Title says it all.
    It is mild steel.
    44
    GTAW
    15.91%
    7
    GMAW 75/25
    11.36%
    5
    FCAW
    36.36%
    16
    GMAW CO2
    36.36%
    16
    The poll is expired.
    Looks like flux core to me.
      I'm guessing CO2.
        nfinch86-CANADIAN WELDOR :
        PRETTY ROUGH WHAT EVER IT IS!!! ...Norm:
          6011 or 6010 wire brushed?
            Originally posted by Iron Head
            I’m not even in the right ballpark; I was guessing 6010 or 6011! .....
            IRON HEAD; I AGREE THAT WAS MY FIRST THOUGHT!!.... Norm : Vertical UP ?
              That’s what I was thinking.
              It could very well be gasless flux core! But why would anybody put so much effort into making it look like 6010? When running flux core is so easy in the first place!
              Somebody Is TRYING to Pull A Fast One???... Norm :
                SO what is it?
                Dylan
                RED BIRD WELDING
                "Experience is simply the name we give our mistakes"
                HH-140
                Crappy stick welder
                Victor supper range II
                Makita grinder
                more stuff i don't feel like listing.
                  My first thought was 6010 or 6011. But know I think I am way off and that the answer will be surprising So what is it?
                  Hobart Mega Arc 5040DD (with built in air compressor)
                  MM Passport Plus with Q-gun
                  O/A
                  sold MM 251
                  There are only 2 tools needed in a tool box. 1) Duct tape to fix any thing that moves that isn't supposed to. 2) WD40 to fix anything that doesn't move but should.
                    I would have thought 6010 too. I do see a couple spatter BBs, so no GTAW. The FCAW I have done has never looked that high and textured (I do VERY LITTLE FCAW). The C-25 MIG that I use is usually much smother, so I would say CO2 MIG.
                      I did use the macro setting on the camera.
                        Flux Core...EASY!!?? You must know something that I don't cause I've never been able to run the junk stuff worth a ****. I can run twice the bead with a 6010 as I can with that flux core junk some of you are so proud of.
                        Bryce
                        Triple B Services
                        Miller Thunderbolt XL AC/DC
                        Lincoln AC-225S
                        Craftsman Hand Tools
                        DeWalt Angle Grinder
                        Performance Tools Bench Grinder
                        1994 Dodge Ram 2500 Diesel 4x4
                        1980 Ford F150 Custom
                        1983 Ford F250 4x4
                          Bryce
                          Triple B Services
                          So then the manufacturers of fluxcore have just been selling us a load of crap for all these years?
                          Jeff
                            nfinch86- CANADIAN WELDOR :
                            What seems to be the problem / s you’re having? I can’t think of anything that requires you to pull a trigger harder than 6010!
                            What equipment are you using?
                            What wire are you running?
                            Self shielded flux core is just like running 7018, think of it as a spool of 7018 wrapped around a little drum. Same thing, only way easier to run!
                            I AGREE!!!!........ NORM :
                              Dang it, you guys! I was just starting to think I was a master weldor, what will all the FCAW I do.
