I am having a a hard time with this. I am trying to weld some mitered corners. I am using an Airco Heliarc 250 hf machine. 3/32" gray lanthanated tungsten fine point, just balled on the end. Seems if I get it hot enough to get a "dab" to join them I am burning through. Any pointers? Dave
TIG on .055 or so 1" square tube.
Turbo, Aluminum or Steel?????? Steel, go to a 1/16 or .040 electrode and cut down the amps big time.....smaller electrode so it will be easier to start....also use any filler as a heat sink if you can .Have you tried pulsing with your foot pedal???? If Aluminum, most definitely pulse Hope this helps, PaulMore Spark Today Pleasesigpic
aluminum. Actually it is .065. What size tungsten should I use? How should I grind it?Originally posted by paulrbrown View PostTurbo, Aluminum or Steel?????? Steel, go to a 1/16 or .040 electrode and cut down the amps big time.....smaller electrode so it will be easier to start....also use any filler as a heat sink if you can .Have you tried pulsing with your foot pedal???? If Aluminum, most definitely pulse Hope this helps, Paul
Turbo, on that machine, a pure tung is recommended with a balled point, I would prefer Zirconium Tungsten as it handles amperage better and ***** well. Others may like 2% Thorium unballed or slightly balled, it does want to have spikes shooting out the sides though. At those amps and depending on the EN/EP ratio I would go with 3/32. You can use the Lanthated, but I am not familiar with the Balling ability. The EP portion of your arc will want to ball for you anyway. here is link on tungsten and Aluminum, Hope this helps ya,Paul
http://www.weldingtipsandtricks.com/...lectrodes.htmlMore Spark Today Pleasesigpic
An .065 alum miter weld is difficult. This is one of the few places that I don't rely on the AC to clean my part. I'd stainless brush the oxides off first. And Scotch-brite the filler too. This helps wetting. I'd use 3/32". Then I'd hold the filler on the piece and arc to the filler. The filler will ball, add a little more to grow the ball. Then pedal up until the filler ball wets into the seam. This will give you a little more mass to the edge and then you may be able to push the puddle across; adding filler to cool the puddle. This is where 3/32" filler works better for me than 1/16".
I can't do this if it's not flat.Last edited by Craig in Denver; 10-05-2008, 04:04 PM.RETIRED desk jockey.
Miller Syncrowave 250.
TURBO38T,
I like the technique of starting the arc on the filler and letting it ball. Start the arc where you want, but slide (if using 1/16) the filler in past where the arc will be about 1/8 inch. Start the arc softly and give it amps until it ball$ , this is where sliding the filler in a little more helps. As it ball$, that extra filler that you put in past the arc will suck up and make a bigger ball, then you only need to add enough filler to barely touch both sides of the joint. Increase the amps, staying on the ball , slowly until the ball wets onto both sides of the joint. Then weld happily away. I use that to weld just about all aluminum joints, it really helps to prevent burn through.
Also, I use .060 gold band on .063-.065 aluminum.
Aint it funny how you cant say b a l l s on here?Last edited by Blackbird455; 10-05-2008, 07:07 PM.SYNCROWAVE 200
Atlas 618 lathe (vintage 1960) reconditioned DC
Sioux 3/8 Pneumatic Reversible Drill
Makita Everything else
2400 square feet of Sanford and Son lookin shop space
"Once the spoon flys, putting the pin back in won't solve anything"
USA 15T, 15V
www.myspace.com/blackbird455
http://i100.photobucket.com/albums/m...5/DSC00356.jpg two cans, one welder
Well Turbo?
Any sucess yet?SYNCROWAVE 200
USA 15T, 15V
dont start on a corner.
some one mentioned once to never start on a corner, start in the middle of the piece and work around the corner. i have had great results with this and thought i would add it to the advice given. you may or may not already be doing so.
turbo38t Not yet, I am nursing my ciatic(sp?) nerve.....it's pinched and hurts like heck!
go easy on that, take your time. trust me when i say you don't want to end up under the knife. hope all works out great for ya.thanks for the help
[email protected]
