Originally posted by Sberry
View Post
1 vs. 3 phase
Originally posted by ridesideways View Postexactly. the placebo effect is rampant here, especially if someone thinks they could tell in a blind test if an inverter is running off 1 or 3 phase. hahahah... not going to happen.
Now if you were intending to limit the test parameters to a given welding current within the range of both phase types, then I would agree with you.
I don't have any 3ph tig experience, but my inverter mig supply is every bit as silky as the 3ph transformer migs I've run.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
I hope I don't get held responsible for the acrimony that followed my asking about the effects of three-phase power on the welding arc . . . I'm new here, and don't want to make waves. I would like to ask Iron Head (I can't get through with a PM) about those SA-200s you found for $250 each. Did they need a bunch of work? I've been web-searching, and so far the SA-200s I see are well into four figures.
Originally posted by seattle smitty View PostI hope I don't get held responsible for the acrimony that followed my asking about the effects of three-phase power on the welding arc . . . I'm new here, and don't want to make waves. I would like to ask Iron Head (I can't get through with a PM) about those SA-200s you found for $250 each. Did they need a bunch of work? I've been web-searching, and so far the SA-200s I see are well into four figures.
Like when you're at wally world or wherever.
Doubtful your first one would be a killer deal.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Originally posted by Fishy Jim View PostThe inverters max power is greatly reduced on single phase.Dynasty 350DX
Dynasty 200DX TigRunner
MM 350P
MM Passport Plus
Spectrum 375 Extreme
08' Trailblazer 302
Here's your 350 *right off the website this minute:
Input Power
208-575 V, 3- or 1-Phase Power
Rated Output
3-Phase: 300 A at 32 V, 60% Duty Cycle
Single-Phase: 225 A at 29 V, 60% Duty Cycle
Same duty cycle, lower output current.
Here's the 200's literature. Same thing - output on single phase 70A lower.
Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Smith O/A rig
Did you just post "rated outputs" in a discussion about maximum outputs?
And your Dynasty 200 link is a July 2004 product guide. He was very specific that he was discussing the latest generation of Dynasty 200, so I'll see what else I can find.
Looking at the product spec sheet for the Dynasty 350 CLEARLY shows EQUAL maximum outputs for single- and three-phase.
This is where you say "Oops! You're right guys, I was looking at the wrong thing; sorry!" But somehow I'm sure you'll Obama your way out of it.
Originally posted by MAC702 View PostLooking at the product spec sheet for the Dynasty 350 CLEARLY shows EQUAL maximum outputs for single- and three-phase.
This is where you say "Oops! You're right guys, I was looking at the wrong thing; sorry!" But somehow I'm sure you'll Obama your way out of it.Dynasty 350DX
MM 350P
MM Passport Plus
08' Trailblazer 302
Originally posted by Fishy Jim View PostHere's your 350 *right off the website this minute:
Input Power
Rated Output
http://millerwelds.com/pdf/spec_sheets/AD4-8.pdf
Originally posted by KB FabricationsThis is at best misleading and in reality, completely untrue. For instance, the maximum output of my Dynasty 350DX is 350 amps whether it be single or three-phase power. That said, the duty cycle is reduced when running single phase input power but not the max output amperage. Furthermore, the newest version of the 200DX (which I have) has identical output amperages/duty cycles between 230V single phase and 3 phase input powerDynasty 350DX
MM 350P
MM Passport Plus
08' Trailblazer 302
Ok, so if the duty cycle drops substantially (my invision 354mp has a 100A hit on the top output on single phase which is not compensated for with a reduced duty cycle beyond being dropped to 20% - which is virtually useless in tig), you still wouldn't notice the machine kick out when it hit thermal protection without looking at the dial?
Can you honestly say that you wouldn't notice a machine with a 20% duty cycle at full power? Weld for 2 minutes and wait for 8 to get back to work.
Kevin, I'm happy you get all the brand new stuff. Post up some literature supporting it if it's available to the general public, because if it isn't the point isn't valid. That it exists means nothing if you can't buy one yet.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Smith O/A rig
Originally posted by Fishy Jim View PostKevin, I'm happy you get all the brand new stuff. Post up some literature supporting it if it's available to the general public, because if it isn't the point isn't valid. That it exists means nothing if you can't buy one yet.
Dynasty 350DX
MM 350P
MM Passport Plus
08' Trailblazer 302
Originally posted by Fishy Jim View PostCan you honestly say that you wouldn't notice a machine with a 20% duty cycle at full power? Weld for 2 minutes and wait for 8 to get back to work.Dynasty 350DX
MM 350P
MM Passport Plus
08' Trailblazer 302
