Well, i've never really done much stick welding but since i have opened the doors to the public and commercial work i've come upon more and more projects that require some stick welding. I can usually get a decent bead, but nothing to write home about.
I've been using some 6013 on my recent projects because i was told it was a good all around rod by the local welding supply store. The only rod i've bought before is some nickel for cast which i grind the flux off of and use it to TIG with.
My main problems are a LOT of sticking when the rod is long (once it's half down it starts nicely every time) And a lot of spatter no matter what length of arc i seem to use.
I'm using my Dynasty 200DX to stick weld with and i haven't messed with the "Dig" as i haven't seena good explanation of what it really does. I also havne't messed with the Low open circuit voltage either as i like where it's at when i'm lift arc TIG'ing, and the manual really doesn't say if the OVC is able to be set independantly for stick and TIG processes.
My usuall settings are on DC welding at between 90 and 110 amps.
I've read all of the stuff on the MIller website under Resources/Improving your skills, but there really isn't much there compared to MIG and TIG info they have
I want to change to a better type of filler rod since i've learned that 6013 is less than ideal for most things (more interweb learning) So can anyone give me info on 2 good sticks (i was thinking 6011 or 10 and some 7018)
Also, can anyone recomend and or explain settings for "dig" and wether or not the OCV is the same for TIG and stick and a recomended setting for it for certain rods?
And i have ONE TIG question.. the start polarity, start amps and start time are a few other things i don't completely understand what will be effected if they are changed except for starting amperage. Which i want to bring the starting amps down to get better at the "beer can welds" I've done pretty good but often blow holes in them on startup, so i've been thinking about bringing start amps down to 10 from the default 40 but don't want to have to change it all the time since i haven't memorized how to navigate the hidden menus as of yet.
Any help is apreciated, and although i just registered today, i've been reading on here for about a week now and love the forum, just wish it was a tad bigger.
