SS Tubing Source
  • SS Tubing Source
    Anyone help me with a source for stainless tubing for a boat railing/bow pulpit?
    Wanting 1" and I think it is .063 wall, prefer polished that I can touch up after.
    If anyone is/has done this type of work I'd really like to pick your brain about a few other things.....pitfalls...etc.
    Thanks
    Ed
    McMaster Carr and/or WW Grainger has that kind of stuff including the supports and anchors. You check it out on-line. You can build just about anything out of those two catalogs.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
      Thanks, but I am looking for 1"and WW only has 3/4. And really wanting a better value.
      Also looking for 10 or 20 ft lenghts.
      So far West Marine has about the best bargin.
      also mis-spoke about wall thickness wanting .049.
        http://www.onlinemetals.com/index.cf...liate%20id=306
        Give this place a shot, there prices aren't too bad but the longest length you can order I belive is 8' which I think you might find is pretty common because of common carrier limitations, unless your order large quantities.
        Hope it helps
        Aaron
        MILLER 180 W SPOOL GUN
        MIller CP 300 w/S22-A Feeder
        Miller Syncro 200
        Miller 375 X Plasma
        Miller Elite Hood
        JD2 Bender
        Tube Notcher
        Horizontal/ Verticle Bandsaw
        Makita Angle Grinders
        Arsenal of handtools
        Evolution Raptor dry saw
        Single Stage 60 Gallon Compressor
        Delta Drill Press
        "No fear to learn by doing", and a degree in Redneck Engineering
          Thanks Aaron,
          It's a UPS thing on the 8'. Truck frt. will ship 20'
          I just can't beleive I can't bet West Marine prices from a metal supplier. But I sure can't find one.
            Originally posted by etonline View Post
            Thanks Aaron,
            Exactly, do you have anybody locally? I know I have a steel place here and if I ask my guy can get in anything I want, the only downfall being I have to order 20's but even then his price beats ordering online for smaller quantities. So give your local steel place a shot, unless ya live in the sticks, ahaha
            Miller Syncro 200
            Miller 375 X Plasma
            Miller Elite Hood
            JD2 Bender
            Tube Notcher
            Delta Drill Press
              McMaster Carr (mcmaster.com) page 1865. Brass and 316SS plus all the supports and fittings. However 8' is the longest length.
              Syncrowave 180 SD
              *HF-251D-1
              PakMaster 100XL
                etonline, Maybe if you posted your location it would make it much easier to help you. Someone on here may be just around the corner from you with the magic answer. Dave
                  You're right Dave. Thought i had put that in my profile.
                  But at any rate i'm in central iowa.
                  I will check the other supplier in town to see.
                    ss tubing
                    try mcnelius steel (sp.?) in southern mn.thats where the place i work buys from and we do a lot of stainless.
                      Looks good shoprat thanks.
                        As another option, you might google Burns Stainless. I know them as a vender of auto exhaust system tubing, but maybe they have what you want at a reasonable price.
                          Give "U.S. Metals" a try.
                          They stock a lot of stainless, alloy and exotics in pipe, fittings & valves. Mainly for process & power piping but they are worth a shot.
                          They probably have a yard closer to you but they are based out of Houston 1-800-676-7836.
                          JTMcC.
