vertical mig gas
  • vertical mig gas
    Is it possible to run vertical mig with 98% Argon 2% Oxygen gas?
    Welders do it hotter!!
    www.Munsonworks.com
    MIG typically only runs out of position when in the short circuiting transfer mode. Otherwise it runs to hot, the puddle will not hold. FCAW works good for this due to its fast freezing slag to hold everything where it needs to be.
    "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful."
    -- Seneca the Younger
      Clavacle,
      Unless you're using a mig with pulse capability (MM350P, etc), I think you're going to find that the 98/02 is a little hot (too fluid a puddle) to use for vertical welding. 98/02 is best for use in spray transfer when using a limited output mig (requires less amps than a 92% Argon/8% CO2 mix).
      You'll get much better results with C25.
      Syncrowave 250 DX Tigrunner
      Miller MM 251 w/Q300 & 30A SG
      Hobart HH187
      Dialarc 250 AC/DC
      Hypertherm PM 600 & 1250
      Wilton 7"x12" bandsaw
      More grinders than hands
