Not impressed with elite helmet
  • Not impressed with elite helmet
    I just bought a used elite helmet off ebay and i'm not very impressed with it. ITs nice to have the bigger viewing area put i thought it would be more clear then my cheap HF hood. I tried both right after each other and i can see no difference and at least my HF hood has auto on with my elite one doesnt' because its 3yrs old.
    More clear???
      Originally posted by TS-Off-Road View Post
      More clear???
      Some folks have stated that they seem to have a Clearer view through better/ $$ Hoods.
      I have a HF and an Optrel Satellite which look the same to me but I bought the Optrel for the options it offers as well as the better head gear.
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        Don't mean to steal you're thread. I just want to know if, i can use one helmet for both TIG/MIG? I know stupid but very about this.
        MILLER MIG 252
        MILLER TIG syncrowave 180 SD
        DIGITAL ELITE INFERNO HELMET
        MILLER MIG 175 (SOLD)
        MILLER PLASMA 375 (SOLD)
          What i meant about the clearer view was ppl where saying that the higher priced helmets had a better crisper view. I don't see the difference, the bigger window is a lot nicer and so is the head gear but i don't think its worth the extra money over the hf hood, but thats just my opinion.
            Yes & No
            Yes because you can- no problem.
            No because if you have a Fixed shade hood with a 13 shade in it, it may be too dark for Low amperage Tig welding- and really any low amperage welding.
            Yes- You can just change out the Shade and use the same hood.
            .... and thus the benefit of a variable Shade Hood.
            Ed Conley
            MM252
            MM211
            TA185
            O/A set
            SO 2020 Bender
              Originally posted by Broccoli1 View Post
              Yes & No
              13!!!! THIRTEEEEEN????
              Man oh man, thats a lot of darkness!!!!
              I'm certain I could not make a decent weld with a 13 lens even at 847 amps or so.
              You're making that up, unless it comes with the BAF option.
              But that's just me.
              JTMcC.
                But that's just me.
                JTMcC.
                Making it up I suppose but I see Fixed Shades listed up to #14 ??
                If #13 is too dark for 847 amps why does the Elite and others go from 9-13?
                Ed Conley
                MM252
                MM211
                TA185
                O/A set
                SO 2020 Bender
                  Humor is a good thing dude. Don't fight it. Let it flow
                  I've got several brand new, in the package, 1980's vintage, Lincoln Supervisibility #14's, I've been totin em around since about 1989.
                  I didn't say 13 was too dark for 847 amps. I said 13 was too dark for ME at 847 amps. Big difference. What i usta see clear thru a 11, now calls for a 9.
                  I wouldn't use a 14 till around 972 or maybe 981 amps.
                  Your mileage may vary.
                  JTMcC.
                    JTMcC.
                    Me? Fight humor- now that's a first
                    It was a question to you- not questioning you
                    Ed Conley
                    MM252
                    MM211
                    TA185
                    O/A set
                    SO 2020 Bender
                      My last day of school (work) was Friday, I'm on summer vacation and therefore don't have to answer questions. Unless you're with the FBI or ICE.
                      I was only joshin you man, use whatever shade you like. You knew that. Over and out.
                      JTMcC.
                        How dark should it be
                        I'm a noob to welding but learning. I bought a cheap princess auto (US equivalent to Harbour Freight I believe) Auto dark helmet. 9-13 shade. I seem to have to crank it to 13 to get enough darkness out of it, even then it still seems to bright. I'm using flux core, don't know if that matters. With the helmet cranked I can see the arc, but not so much the puddle. I tried my prescription sunglasses underneath and turned it to 9. I can see the puddle perfect and my eyes are not getting fatigued.
                        Here's the question - When your helmet darkens and you look at 2 bulb florescent fixture from 2 feet away - how much do you see? Dim shapes? the full bulb and fixture?
                        If someone could gauge it for it me would be very helpful. If not I'll take a video holding the camera behind the mask and behind the mask with my glasses. Not sure how it will work out though as the camera has a eyris that will close up.
                          what shade do you use?
                          Hi guys
                          I have two hoods (1)huntsman fixed#8 and speedglas 9000x new style and I use them for different applications and how I feel when welding.
                          Also you can get a chart from these links to see what the specs are for lens shades
                          www.ansi.org
                          www.csa.ca
                          www.cdc.gov/niosh
                          www.osha.gov
                          www.aws.org
                          I hope this will give you a better idea of shades to use and for what apps
                          Syncrowave 250/Coolmate-3-(home)
                          RMS-14 (kisser button)-(home)
                          Craftmans/S-K tools-(home)
                          Grizzly 16" vert band saw-(home)
                          DeWalt chop saw-(home)
                          Craftsman 4"-7" hand grinders
                          Lincoln 225 arc welder
                          Lots of vise clamps(not enough)
                          assortment bar clamps
                            No magic here
                            how about a basic thoght?
                            Too bright? use a darker shade.
                            Can't see? use a lighter shade.
                            I never use darker than 10
                            Jeff
                              The Shade is there for Comfort.
                              AD Hoods: The lens protects you from the harmful wavelengths of light in it's Clear state.
                              It is going to be different for each individual.
                              The Charts are Guidelines Not "law"
                              As Jhall and JTMcC stated use whatever works for you.
                              Ed Conley
                              MM252
                              MM211
                              TA185
                              O/A set
                              SO 2020 Bender
