I have a bobcat 225 nt w/ no cables. I was wanting to put 50 feet of each. I would like to know if 2/0 gauge is big enough to do medium welding? Any help is appreciated.
Welding Cable Lead Size???????? Help
The cable size is determined by amperage and length of lead. I would get cables to handle the max output of the welder but if you know you will never run that high then I guess it could save some $ to downsize. There is charts that should not be hard to find if you google it but I'm sure you're LWS has the chart handy. If you plan to by off the internet from a welding supply, they probably have the chart listed with the cable.To all who contribute to this board.
My sincere thanks , Pete.
Pureox OA
Westinghouse 300 amp AC stick
Miller Syncrowave 250
Hexacon 250 watt solder iron
Originally posted by burninbriar View PostIf you plan to by off the internet from a welding supply, they probably have the chart listed with the cable.
https://weldingsupply.securesites.co...F:OR:304-1170RTo all who contribute to this board.
Pureox OA
Yes, 1/0 would be plenty and I would be tempted to add another 25 ft of lighter cable to the whip end. It would cost less, 50 ft might be plenty for ground but 50 is too short by a pinch for electrode holder. Also the small is going to be easier to drag around and cheaper to replace when worn.
Cables
If you go with 2/O, you will be fine. If you go with #2 and want to go further than 50', you won't. Go big if you can afford it. Sometimes the work is further away than you can get to! Trust me, it happens.Millermatic 210
Syncrowave 200
Spectrum 625 X-treme
Hobart Champion 16 W/
Miller 8VS Suitcase
Miller 3035 Spool Gun
Tons of Tools
Microwave
Laptop and Printer
Speakers in the Back for all to hear Sirius Radio!
