I've never had much luck clamping things to keep them square. They end up square while clamped and even if I let them cool completely before un clamping they still ended up moving. Until I figured out that the sequence in which you weld the joints is extremely important. In my opinion best way to keep square is, tack the pieces. Make it square. Clamp if you want. The most important part is to weld one corner then immediately weld another corner that will draw against the first. Can't take a break in between two opposing welds. Can take a break after a set of welds. This way the first weld is still hot and drawing in while the second is being made and they both cool as closely as possible to each other cancelling out the draw
Corner clamp recommendations?
