I have a DW872 saw which I like. The original blade on it needs to be sharpened. I just purchaced a elec saw blade sharpener from Harbor Freight
on sale for $59. It comes with two wheels........one amber and one diamond.
It seems well made for that price.
Anyway..............the original blade has a wierd center hole shape that requires an aluminum ring spacer/adapter to fit on the saw. I also have a new replacement blade by Dewalt for the saw. It has a round center hole and doesn't need the aluminum ring to fit the saw.
Both blades are DW7747 by Dewalt. The carbide tip faces on the original blade are ground flat, perpendicular to the side of the blade. Near the center is MYJ9.
The new blade has MYA6 in the center. I wonder if this is actually an older blade. This is why I'm curious. The replacement blade has the same Model #, same 70 tooth, ..........but the carbide teeth are ground differently. The face of each tooth is ground at a 7 degree angle, but one tooth is ground on one side and the next is ground the opposite. I wonder why. This blade has the grind angles printed on the blade. I am wondering if the newer blade is actually an older style going by the letters/numbers in the center. The blades are not cheap so the HF sharpener seems like a good deal. I never have sharpened a blade before so it took me a while to set it up but the 70 tooth blade took less than 10 min to sharpen with me double checking. Any other input about these blades from Dewalt owners would be appreciated.
Nick
Here is a link to the sharpener:
http://www.harborfreight.com/cpi/cta...emnumber=96687
I would imagine, being that it has a diamond wheel, it would make a great tungsten sharpener.
Nick
