I bought a year 2000 L35 used late last fall. I drew up the parts for a mechanical thumb, and they are being cut out on a CNC plasma. Then I will weld up the thumb and install it.
The problem is that the inside (operator-facing) flat surface on the dipperstick where the thumb base will mount has a bulge in it. The bulge is in the area between the the pins for the bucket linkage. Apparently the previous owner really stressed this thing at some point, but it was likely the only time because the whole machine is in great shape.
I talked to the dealer and what they would do is cut out the bulged area and replace with a new piece of plate. Which is what I thought they would say. They have never done this repair before. They did not know if the steel was an alloy steel or just mild steel.
I definately will not spend the $1,000 bucks for a new dipperstick.
What do you guys think?
Thanks,
Nick
Thanks,
Nick
