I need to know how to give a brushed finish to an aluminum pipe that came mill finish.
Aluminum finishes
That's a big piece of aluminum.
If you must have the grain running radially, then yes, your jig would be the ticket towards perfection. If you have a lathe and can chuck the tube up and extend it off the bend with proper support, I'd say go for it.
Sometimes you just gotta jump in and work it out.
I think you'll find that "perfect" quickly becomes a relative term.
Good luck, El Guanche, and I'd LOVE to see some pics of how you go about this.Maxstar 200DX
Maxstar 300DX
Passport
Spectrum 701
LMSW-52 spot welder
I think your lathe fixture idea is a workable solution. We have put brushed finishes on small parts using lathes and abrasive cloth, paper, or scotchbrite, so it should work the same on a bigger scale. If you don't know someone with a long enough lathe bed you can just rig up somthing to turn the tube. If you don't have enough waste length to chuck up without scratching the material, you could make some inserts to fit inside the tube and have small enough spuds sticking out to chuck up or support on the tail end. You could use a belt wrapped around the tube driven by any motor if you don't have access to a lathe. Hopefully your customer will pay you enough to git er done.
Good luck,
Rube GoldbergBFM
Passport Plus
Bought the machine and it works wonderfull. I started with #30 grit then #60 and finished with #120. It gets a little hot both the machine and the aluminum. It took me about 2 hours to do the whole thing. Ain't that amazing". Last time it took me more than 8 doing it by hand and it wasnt that uniform.
This is the machine the picture is from the site http://www.csunitec.com/sand/pipe_sander.htmlAttached Files
El Guanche:
Thanks for the pic. That thing costs $990? Does it have variable speeds or one speed fits all? Are the belts specific to alum? Did you turn the tube by hand or machine? Sorry, pics cause questions; like marriage causes divorce.RETIRED desk jockey.
Miller Syncrowave 250.
It is variable speed, I did it in segments rotating the pipe about 1/10 of the circumference at a time and it blended well with no banding, I moved the machine the whole lenght of the tube back and forth with each grit starting at 30 then 60 then 100 and left a nice radial pattern just like a factory made brushed finish. The belts I think are good for aluminum I welded afterwards with no problem at all.
