pickup truck crane woes...
  • pickup truck crane woes...
    Good day all...
    Am in the process of making a crane to mount in the back of a pickup truck... I'm using 3.5" x 1/4" pipe for the mounted piece and of course a 4" x 1/4" to slide over and swivel on it...
    The problem is the 4" pipe isn't seamless... Anyone know of some process besides getting a piece of seamless pipe to get the seam out of about 3 feet of that 4" pipe ???
    thanks
    r00n
    MM 212
    MM 140 a/s
    Canox 225 sparkler
    HT powermax 380 plasma
    Oxy/prop torch
    14" Delta chopsaw
    I can't think of any. Seamless comes from the DOM ( drawn over mandrel ) as opposed to the normal rolled pipe. If you need one tube to fit inside the other that another specialized product. The dimensions are different than standard pipe.
    Dennis
    Thermal Arc 185-TSW
    Millermatic Challenger 172
    VictorO/A
    Atlas Craftsman 12 by 24 Lathe
    Esab PCM-875
    Wholesale Tool Mill-Drill
      talk to ur steel supplier and find some with close tolerances.
      trail blazer 302
      hypertherm plasma
      millermatic 251
      high feq. arc starter
      suit case (extreme 12vs)
      o/a torches
      way to many other tools to list
        Originally posted by r00n View Post
        Good day all...
        thanks
        r00n
        What type of crane are you getting or using, I'm thinking of adding one to the back of my 1 ton.
          Instead of using pipe with 0 tolerance fit, you could use pipe sizes with a looser fit and install shims at the ends of the larger piece to tighten the fit on the smaller one, this will also reduce friction when you swivel it with a load on.
          My sincere thanks , Pete.
          Pureox OA
          Westinghouse 300 amp AC stick
          Miller Syncrowave 250
          Hexacon 250 watt solder iron
            Or do what I did with my jib crane and insert roller bearings top and bottom into a 1/4" tube and a T-1 matching shaft in the center. Or I was thinking find a shaft and outer case with close tolerances and tap in a couple of grease nipples. It would turn easy & never corrode.
              you could use pipe sizes with a looser fit and install shims at the ends of the larger piece to tighten the fit on the smaller one.
              I do this on my trailer ball receivers (male end) to keep the dang things from rattling. You can make it as snug as you want.
              RETIRED desk jockey.
              Miller Syncrowave 250.
