i have heard of it but any welder i have ever talked to has never actually seen it happen.I personally dont unhook any thing and i mainly work on heavy forestry equipment that have alot of electonics and have never had a problem but i always make sure my ground is next to me.if the customer expresses a concern,i just tell him that if he is worried then he can unhook what ever makes himhappy.
Precautions mig welding on my truck?
i have had it happen, fried a ecu on a westernstar, dam helpers..... any one that is actually a welder will know about stray arcs and what that many amps and volts will do to wiring. its true and any one that says not to, go back to school and get educated. its just common knowledge to do this at least around here. dont mean to offend any one its just this is what i do and know and i know whats right and wrong.trail blazer 302
hypertherm plasma
millermatic 251
high feq. arc starter
suit case (extreme 12vs)
o/a torches
way to many other tools to list
Originally posted by TS-Off-Road View PostHey, you gonna' build roll cages for skateboards now with your new bender??I'm gonna have the MEANEST, MOST AWSOMEST SKATEBOARD INT THE WORLD (of course the skateboard's gotta be the same size as a truck, but wouldn't that be cool to see?
I'm not late...
I'm just on Hawaiian Time
QUOTE Sberry:
I think in most cases its a hazard and a liability to hook/unhook the battery, I never do it.
Far as what Sberry said, I could see a lot of it (eclectronics) having to reprogram (besides the radio) that might be a pia...Think I'll stop doing it...I'm not late...
Originally posted by cruizer View PostAutobody shops don't disconnect anything.
I was curious today and inquired on what they did. I'd say to simply make sure you have a good Gound point for your welder.
JimWelding in Crete
Syncrowave 350 LX
Millermatic 252
Millermatic 180 w Spoolgun
Miller Gold Seal 155
Miller Elite welding helmet
JD2 Tubing bender with Hydraulic conversion
Evolution Raptor15" SteelDry Cut Saw
Hypertherm Powermax 30
Some really cool hammers BIG and small
For sixty bucks I bought a surge protector, hooks onto negative and positive terminals on the battery and prevents havin to unhook the terminals, so far so goodTrailblazer 302G
MM 210 with spool gun
Thermal Arc Heffty2 CC/CV suitcase
Smith torches
Porter Cable 14" carbide chop saw
griders and hand tools coming out the WAZOO
I owe! I owe! so off to work I go!
I read a few of the replies....(FYI ecm = engine control module so it doesn't control the tranny, or acc.) I'd rather take the few min. to disconnect them on a newer vehicle than have to replace them....my reasoning is this some of the signals to and from the control mods are as low as 0.5 volts so if I was welding @ say 18 volts....that would be like plugging a 9 volt cordless drill into a 320 volt supply...not me....some of these control mods cost some big $. For your 95 Toy I'd remove the battery cables and have at it.George W. Bush was saving your butt whether you liked it or not!
Fear is temporary, regret is forever
HH210 with SG
Originally posted by Bert View PostWOW! You think you're better than a lot of the pros here???!!!!
Why you upping your price???!!!Welding in Crete
Syncrowave 350 LX
Millermatic 252
i always unhook the grounds .on all of our equipment it says unhook ALL grounds for chassis and engine ecm.i dont go that far it would take longer to do that then do the job.that said years ago on a non computer mack, i left the batteries hooked up and went to start it. blew the tops off two batteries http://www.millerwelds.com/resources...milies/eek.gif
maybe just a coincidencehttp://www.millerwelds.com/resources/communities/mboard/images/smilies/confused.gif
...bill
Originally posted by Bert View PostYepI'm gonna have the MEANEST, MOST AWSOMEST SKATEBOARD INT THE WORLD (of course the skateboard's gotta be the same size as a truck, but wouldn't that be cool to see?
start bendin'
http://www.worldsbiggestskateboard.com/about.html
