I was just wondering if there is a way to differentiate one type of stainless steel from another? I think some types will be attracted by a magnet...
I found a nice scrap today and I grabbed it thinking I could use it to try to tig weld on it.
I have some ss rod; long day and too lazy to go look but 308 seems to ring a bell...
I thought I read something here that this was for welding ss to mild steel, but this seems to be what the lws has for ss.
I was thinking I would first try to cut some small scraps and fuse them with no filler. If I do that should they be backed up with something or suspended? Then maybe lay a bead with filler on top of a piece then move to a joint... Does that sound like a good plan?
The material is maybe 22g or a hair heavier, but not 16g I don't think. I'm thinking 1/16 tungsten with a 1/16 rod when I get to that.
Maxstar 150 STL - do I crank it up - hot and fast?
Thanks in advance, you guys are the best...
