hello all. I have a old Hobart Cybertig welder. (1976) I am running it in its 220V mode (it's a single phase machine) The 110V panel where I am is boogered up (both busses are fed off the same meter terminal) so I was forced to grab 120V off two legs of a 3 phase panel. So basically I am running my welder on 208V from a 3 phase box. I know that in a standard residential 110V panel, the voltage is coming in at 60HZ but the phases are 180 degrees out from one another. In the three phase box, I should still be getting 60HZ, but each phase (3 of them) are 120 degrees out from one another.
I would appreciate everyone's thoughts on if this would affect the functionality of the welder in any way. I.E. the cleaning of a AC aluminum weld etc.
Thanks!
Thanks!
