For an experimental aircraft application, is there an issue with using a plasma cutter on 6061-T6 Aluminum sheet?
The application would be structural parts. The parts are riveted together after shaping.
Looking at the option of scratch building vs buying the kit. (kit has laser cut parts)
Specifically, will the heat of the cut effect the metal in a bad way?
One practice recommended is stacking blanks together, then using a band saw to cut out parts. I was thinking plasma cutter with a pattern guide would be faster. Both processes would have edge clean up, not sure about the heat zone.
Any thoughts?
Thanks,
Tom
Any thoughts?
Thanks,
Tom
