I was wondering what you guys run for welding cables. gauge and length.
Which gauge cable seems "too big" to comfortably weld with, without becoming overly fatigued? I ask because I want to be able to run as high of amperage as possible at 50' but not also have this very heavy cable for my stinger lead.
I'm planning on only running at most 250 amps for stick welding with my SAM-400 at 50ft. I know that I'll need much bigger to run full amperage with my SAM-400, but to simply keep the cost down I want to try to use smaller cables. My plan is to get smaller cables and just not run the machine over 250 amps. And if/when I do need the higher amperage I'll go buy bigger cables.
I have figured out a couple solutions, which one is best I'm not sure, thats where i need help
Plan #1-75' of 2/0- 50' of ground and 25' of "electrode", then i would buy 25' of say either ultra flexible #1 or #2 as a whip
Plan #2-100' of 1/0 just split it 50/50
Plan #3-75' of 1/0- 50' of ground and 25' of "electrode" with a 25' whip of again #2 ultra flexible cable.
or Plan #4- 100' of #1 split 50/50
Now which one seems most user friendly and the cheapest? and Im not set on using one of these 4 plans, any suggestions are welcome.
Thanks, Mike
Thanks, Mike
