I've been called to weld on a "super' stainless vapor tray that is made from Alloy 20. Problem is, I have no idea what type of rod/filler that this will require.Anyone have a suggestion.
Mike
MACH4
Alloy 20 or Carpenter 20 as it was called is welded with Alloy 20 rods. They have a lime green coating on them. I welded that stuff every week. The rods are not cheap either...Bob
