Originally posted by admweld
View Post
Your right, Yours may have an injector pump up front if its older than about 1994. And the fuel pump or lift pump is a lever type pump mounted on the side of the block. About 94-95 or so, they switched to electronic injectors, that are oil operated and the mechanical fuel pump was then moved to the back of the valley. Sometime around 96 ?? they moved the fuel pump to the frame rail and its electric. Lot of guys get the fuel pump and oil pump mixed up. The 6.0 "oil" pump is in the rear and the fuel pump is on the frame. They no longer have injector pumps like the old diesels. The high pressure oil pump supplies high pressure oil to operate the injector and the injector is electrically controlled by the PCM[computer]. The high pressure oil acting on the injector is actually what causes fuel to be sprayed into the cyl. The fuel is in a galley surrounding the injector body.
If yours has an injector pump up front then the injector pump forces fuel under high pressure to an individual nozzle that sprays fuel into the combustion chamber.
Sorry for the long explanation
