Just wondering what would be easier to use or better?
I am cutting the front radiator support off a vehicle. It is a typical upper radiator core support that is hollow in the center. I would like to cut the factory piece out, close (box) the ends shut and put a stainless steel bar across where I cut the OE piece out of. I know alot of body work is done with a MIG but would the TIG make is easier to not have to grind down the weld when done? This will be my first attempt at body work welding like this. Also I assume a weld thru primer would be good to keep the inside of the piece I just cut from rusting inside-out
