Portable welder is building a Pipe Welding Rig
at home:
2008 Suitcase 12RC
Spoolmatic 30A
WC-24
2009 Dynasty 200DX
2000 XMT 304
Sold:MM130XP
Sold:MM 251
Sold:CST 280
at work:
Invision 350MP
Dynasty 350
Millermatic 350P
Originally posted by gweld View PostJ Hall,
Nice rig. What do you use the outrigger/jacks for and how did you weld (joint types) the tubes to the bed?
Happy New Year
Gweld
The tubes are just welded to the back of the bed.(it's 3/8 plate) I put them on when I mounted my crane.Attached FilesJeff
J Hall I dont seem to remember your rig, howabout some more pics, you have alot of weight on the passenger side by the looks of it.
Nice looking functional rig, I ddint realize the picture you sent showing the lip on the back was your truck.
The only thing I see wrong with your truck is that the crane appears to be 100' to short.
I know mine is.
If your like me I droul over the big boom trucks.
once in a while I rent an enclosed cab 28 ton boom truck with an operator of course, on a sterling chassis.
A new one is about $ 230,000.00
OK Ive seen it, The pic from the other side made it look different to me.
I see the welder and tanks are on the driver side to balance the truck out.
J Hall do you have the same problem I have, does your truck get stuck in the slightest bit of mudd or did they make limited slip an option.
There was no option in 1999 for it.
Originally posted by Portable Welder View PostOK Ive seen it, The pic from the other side made it look different to me.
There was no option in 1999 for it.Owner of Burnt Beard Fabrication & Welding Ltd.
BigBlue 500D
Millermatic 211
4' Box and Pan Break
IR compressor
Originally posted by Portable Welder View PostYour right, I need to check into a way to lock it together when I get into the mudd, The probem is that you have to be able to unlock it on the pavement because the weight of the truck.Owner of Burnt Beard Fabrication & Welding Ltd.
BigBlue 500D
Millermatic 211
IR compressor
Originally posted by shorerider16 View PostI'm pretty sure the Detroit is a selectable locker that is electronically controlled. The ARB is for sure, it uses compressed air to actuate it so you would either need to plumb it in to your rig's compressor if you've got one or by one of their mini compressors. There are other brands of lockers out there but the, Eaton, Aburn... try checking out a 4 wheeling magazine. No matter what route you go, it will still beat the classic one tire fire!at home:
2008 Suitcase 12RC
Spoolmatic 30A
WC-24
2009 Dynasty 200DX
2000 XMT 304
Sold:MM130XP
Sold:MM 251
Sold:CST 280
at work:
Invision 350MP
Dynasty 350
Millermatic 350P
So how did your friend make out with his turn/ tail/ stop lights on the new deck? How's the rest of it working for him, would he get you to do anything different? Is he happy with the cable wells?at home:
2008 Suitcase 12RC
Spoolmatic 30A
WC-24
2009 Dynasty 200DX
2000 XMT 304
Sold:MM130XP
Sold:MM 251
Sold:CST 280
at work:
Invision 350MP
Dynasty 350
Millermatic 350P
