Spoolmate 100 ??
  • Spoolmate 100 ??
    Anyone know what is a Spoolmate 100? Suppost to be compatible with Millermatic 140 and 180, but can't find any info anywhere at all. Saw a tag on the 140 at the BOC store about it.
    Thanks
    Millermatic 180
    Syncrowave 200
    Spectrum 625
    I just saw it mentioned over at the Pratical Machinist Forum. Maybe its a smaller 3035...Bob
      Thanks AA, I'm very excited to see that it's going to be affordable.
      Can't wait until it's out, should offer me a few more options in projects.
      Millermatic 180
      Syncrowave 200
      Spectrum 625
        One of the ebay online stores has 30 of them, can't remember which one though.
        Regards, George
          There is a Spoolmate SGA 100.
          It's an adapter box for connecting a 3035 to a MM welder.
          I've never heard of a spool gun by that name.
          edit: I found it. Looks just like a 3035
          $195.99 on eBay
          Miller # 300371
          Spoolmate 100 Series spoolgun for Millermatic 140/142s and 180/182s
          Specs:
          135 amps at 30% duty cycle
          Spool size: 4 inch
          .023-.035 inch aluminum, steel, and stainless steel wire
          Features:
          Carrying case for easy portability and storage of consumables
          Adjustable drive roll tension for feeding different types of wire
          Pressue lever for easy loading and unloading of wire
          Clear spool cover shows amount of wire left on spool, extending contact tip life
          12 ft heavy duty cable with strain relief
          Recessed contact tip for prevention of burn back issues
          Dual V-Knurled drive rolls provide consistent feeding
          Heavy-duty motor and cast aluminum gearbox
            Thanks...Bob
              Awesome! It looks better than lincolns spoolgun for the 140/180 class machines.
              I may have to get 1 of these.
              Thanks for sharing guys.
              Millermatic 180 DC,Miller Spoolmatic 3,Miller HF-251-D1 __ Lincoln Cobramatic/Cobramatic Gold
              Millermatic 200 with pulse/spot/burnback panel DC ______Lincoln Idealarc Tig 300/300 AC/DC
              Miller ECONO twin HF 150 AC/DC .____________________ Lincoln Idealarc R3R 300 DC
              Miller Trailblazer 250G AC/DC (20hp. Onan) .____________ Lincoln Buzz box 225/125 AC/DC
              O/A Harris, Purox, Victor, Torchweld (To many to list) .___AIRCO wire feeder
                Oops! I think you guys got the online vendors in trouble. All the adds are yanked off of ebay now.
                IOC has this listed in 1 of their mm180 adds,
                NEW SPOOLMATE 100 IS IN STOCK, CANNOT LIST ON INTERNET UNTIL 9/14/07 300371
                Looks like miller is trying to protect walk in stores a little by not letting them be listed on the net for a few weeks. My guess is there must be quite a bit of cost difference somewhere.
                  Just got off the phone with my LWS, and he can get me the spoolmate 100 for $179.00.
                  I was also told, For units prior to serial# LH210051N you need a retrofit kit part#234402 for installing the spoolgun.
                  Looks like ebay isn't the deal this time.
                    For the rest of the evening at least, the manual is available in the Service section of this site.
                      I wonder if it will work with the Hobart 140 / 187....looks like the trigger wires would have to be "re worked" a little.....
                      Mike
                      George W. Bush was saving your butt whether you liked it or not!
                      Fear is temporary, regret is forever
                      HH210 with SG
                        Arent the guns on the HH 140 and MM140 the same just different letter? If that is the case then it should work on the HH 140 just have to change trigger electric end. I would buy one if they would work on the Hobart 140.
                        Steve
                        Update: Theres a DPDT switch that has to be installed in the machine to switch the wire speed between the spoolgun and the wirefeed motor. Wonder if the HH 140 has the same connector?
                        Anyone know how long the cable is on the spoolgun?
                        Dont force it, use a BIGGER hammer.
                        Linde VI-252C and Linde wire feeder.
                        Hobart Cyberwave 300c.
                        HH 140.
                        Miller Big 40.
                        Lincoln SAE 200J.
                        Hobart GR-303.
                        Lincoln tombstone welder.
                        TD Cutmaster 52.
                        Hobart Stickmate.
                        Miller 211 w/ Spoolgun.
                        Lincoln SA 200.
                          I might buy one just for parts for my MM185 spoolmate. Never know when you may need a part in a hurry. I was going to buy a spare motor but its 150 bucks...Bob
                            The bore of the socket, that machine end of the gun assembly plugs into, is a smaller diameter on the HH 140 and 187, then on on the MM 140 and 180.
                              New spoolmate 100
                              message deleted.
                              only purpose for reply was to sell product. not part of original question
