What's The Right Angle For Overhead Welding?
  • SCHOONER
    Originally posted by beamwalker
    wire @ 90 degrees to steel. i dont vary more than 10 degrees. works fer me
    Hi Beamwalker
    What is you approach to over head mig welding?
    At what angle do you hold you mig gun?
    Thanks guy
    GOD BLESS
    Schooner
    QUOTE: I try to remember H.A.L.T.
    Don't get: Too HUNGRY, ANGERY, LONELY or TIRED.
  • beamwalker
  • SCHOONER
    Originally posted by aametalmaster View Post
    You use the angle that keeps the hot sparks from running down your arm. There is no textbook answer to your question because every job is different and its hard to tell if you are coming from a corner or running into one or just welding a bead so you will have to adjust to each weld...Bob
    Hi Bob
    Yeah, I guess your right about angles I just found out today by PRACTICING MY MIG WELDING.
    Thanks for you imput BOB
    GOD BLESS
    QUOTE: No man know just how bad he is till he tries very,very hard to be good.
    Schooner
  • aametalmaster
  • SCHOONER
    started a topic What's The Right Angle For Overhead Welding?
    Hi Guys (Newbie Here Again)
    I'm about to be doing a bit of over-head mig welding.
    I'm new at this, done flat and vertical outcome not bad.
    I rather get it straight from you expert who've done mig over head.
    QUESTIONS PLEASE:
    1. What angle is best when doin' the over-head ?
    I'm welding 18 gauage sheet metal for my restoration.
    2. What HEAT & VOLTAGE setting would you guys use ?
    Thanks guys
    GOD BLESS
    Schooner
