30" Pipe project
  • 30" Pipe project
    Well just wraping up the bigest project I have ever welded 30" pipe std and xheavy wall.
    Here is a couple pictures of the stuff.
    This is the first head building structure on the irrigation piping project.
    Here I am standing in front to give an idea of how big it was. I am 6ft tall and this was in the ground about 10 feet or so.
Name:	d300 manual.jpg
Name:	Henry Comoses Omega mold 002.jpg
    Here is part of the second head building structure. This took me 3 1/2 days of work in the shop. and about 20 hours of weld time. Weight is 4270lbs.
    Me again in the shop just finished welding the last little bit.
    Let me know what you guys think.
    PS Yes i know there is a lincon welder in the shop. The welding truck has a trailblazer 302g, 2050 plasma, 12rc suitcase welding. Trying to get my boss to buy a XMT304 for the shop. Think I have them sold on the idea.
    Gary
    Dry Creek Welding
    Dynasty 300DX Tigrunner
    Trailblazer 302
    Spectrum 2050
    suitcase 12RC
    Very nice work, was it x-ray. The biggest I ever worked was over 60 inches in diameter and it was for a dredge boat that was to be used in Florida to dredge a channel . It did not require any kind of NDT. Again I would like to say very nice work.
    Wheelchair
      Nice work.
      I would like to see the machine that is used to bend that large of pipe.
        [QUOTE=M1.30-'06;89615]Nice work.
        I would like to see the machine that is used to bend that large of pipeQUOTE]
        If you are refering to the 60 inch pipe all of the ells were rolled out in halves in the heavy plate shop and then welded and mitered to suit. The majority was straight and also rolled in halves and butted together . The flanges were cut out of plate and drilled. The wall thickness was 1/2 in and after welding was lined with some type of coating. We did this job yearly in the shipyard as it was worn out completely when the dredge ship came in. Nothing was bent on pipe bender. Hope this explanation helps.
        Wheelchair
          I was actually referring to Gary's project, but thanks for the info. anyway.
            GaryM--What wire did you use on that? Did you use wire in the field also or stick? Looks like a fun job, very nice.
            MM250
            Trailblazer 250g
            22a feeder
            Lincoln ac/dc 225
            MM200 black face
            Lown 1/8x 36" power roller
            Arco roto-phase model M
            Vectrax 7x12 band saw
            Miller spectrum 875
            30a spoolgun w/wc-24
            RCCS-14
              Thanks for the great replys.
              The elbo I think is a cast fitting along with the Tee. Only used one Tee out of 6 rest were coped cuts.
              For wire all the shop welding was with ER70S6 .035 did not have drive rolls for anything else. Field was the same weather permitting. other wise 7018 3/32 and 1/8 rod.
              here is a couple more pics of the project.
Name:	Henry Comoses Omega mold 004.jpg
Name:	Henry Comoses Omega mold 005.jpg
              I guess the hardest part of the project was the oval pipe. Every thing was used and the gas pipe(green epoxy coted) was really bad.
              Gary
              Dry Creek Welding
              Trailblazer 302
              Spectrum 2050
              suitcase 12RC
