Thought it might be a good time to follow grinder rating with a few opinions on grinding discs as well. We have found lots of cheap ones out there but the old adage ya get what ya pay for kicks in & am usually dissappointed in the durabilty. Personally we use nothing but Walter discs & flapdiscs as well. Anxious to here your experiences.
Grinder Discs
for cut-off wheels... nothing but Walter Zip wheels, they're very much worth the money... it took me 16" of 3/8" plate to wear out 1 4.5" wheel. for 4.5" stones, it's either SAIT or walter.. neither seems to work better than the other. for flap wheels I usually use DeWalt.. best I've found for the money.
for my 7", the LWS has far less selection, pretty much flex-o-vit or SAIT. I've had no complaints at all about the SAIT cutoffs (which work amazing on B-deck) or the regular stones. I've got a flex-o-vit concrete cup too.. works well, but man what a heavy combo.Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
For aluminium my favorite is Norton's AVOS speed lock (blue) disks. If you use wax to prevent build-up they last a long time. The AVOS system is great because you can see through the disk to the work. I know it works on steel but I work mostly with aluminium.
Brian
differences
One of the things to look at when picking up grinding discs is the amount of grinding material as opposed to the amount of filler that they use.....
I took a couple of discs off our shelf and took a couple of pics. Picture one is a side by side comparison of two grinding discs. one disc sells for "about" $3.00 each (CDN) and disc two sells for "about" $5.19 ea.
Keep in mind that these discs are the same rating A24-R
the close up pics show that the 'grinding' medium is only about half of the 'cheap' disc...the rest of the disc is made up of filler material that will wear out by looking at it. once you have used up the first 1/8" of the disc, the rest goes away pretty quickly.
I outlined the filler in Yellow on the closeup of disc one. (the pic is a bit blurry, but you get the idea.)
next time you're out disc shopping, take a look at the edge of the disc to see what you're getting.
wow i never looked at a grinding disk like that.
for flap disks the walters seem to last a lot longer than the others and the built in nut shore is nice for changing out, but wow the price tage can get you fast. about $9.50 each at my LWS.i got some off the net for about $2.40 each that worked well but had no nut and did use up faster. so for the daily use on the job site i think the walters could end up being a $$ saver in the long run. for playing at home in the shop out back the e-bay special is probly a better option. i can get a 10 pack for what 2 walters would be at my LWS so even with a shorter life span and needing to use my grinder nut its hard to justify the walter's at home, that being said i had some given to me and man they are nice. for the job market the walters would be my choice for home the e-bayers are fine. provided you get a quality one from e-bay, pionear makes a nice disk for home use. i'll pop a pic of the 2 side by side later on tonight or in the morning if i dont make it out tonight.
thanks for the help
[email protected]
i think i pay 3.50 through a local autoparts store wich i have an account with for the walters, i belive there regular price is only 4-4.50$ ea, vs buying the cheap-o's for 2.99$ reg price, and have them last half as long
you would be suprised what comes up at good autoparts store's, i just recently picked up over 90lbs of 7018 (hobart and air liquide) for about 80 cents a lb (cdn of course)mm210
maxstar 150
Have to agree the flapdiscs are a little pricey but still the way they last compared to others ,still think they are worth it.I always run 2 grinders,1 with grinder disc & one with flapwheel. Some times get lazy though and ask a lot of the flapwheel, but if used only for the last blending they seem to hang in real well.252 Miller Mig
180 Synchrowave
R - 45 Milling Machine
Kingston 1100 Lathe
Miller 2050 Plasma Cutter
