Kohler!!!!
Onan or Kohler or Robin
Kohler is the engine manufacturer that both John Deere and International Harvester usedThat's gotta say something about the company.....
I've personally experienced one on the governor pulling hard for hours on end, as well as a Kohler living at 6000RPM and putting out close to 60HP.... And knowing what they look like on the inside(doing one now), can say they're stout..Curt
Dynasty 200Dx
Millermatic 185
Hypertherm 600
Welder Tue Up KIts
Miller has tune up kits for Kohler, Robin, Kubota and Onan engines on their welders these come with the plugs,fuel filter, air filter and pre filter and oil filters . We carry them all at
http://www.brweldingsupplies.com/par...ndex.cfm?ID=66
2 Cents
Originally posted by Miller John View PostRailmen,
Living in Canada does change my tune a tad. The Kohler is a little more friendly in cold weather and if cold ever does become a problem, Kohler has a couple cold weather kits that can be used. Our Canadian customers tell me that Kohler has more service and support outlets where they are needed in Canada as well.
Have fun with your new machineowner of EVOLUTION WELDING
The Kohler is easy to get parts for, there has been a pushrod problem with them,ie, rockers comming loose and letting go of the push rods, no damage other than a $2 push rod replacement.
When the Kohler finally wears out (around 3000-5000 hrs) It's relitively simple and inexpensive to over haul. When the Robin / Onan needs an overhaul, it's way cheaper to buy another welder at that point than to spend the big dollar on an overhaul or replacement engine.
Don't like the cold weather kits, I find they bake the oil, a more simple solution is to seal the back of the top plastic air cleaner shroud with a piece of radiant insulation, simply doesn't allow cold air to freeze the back of the carb. And it's 50 cent reliable and hassle free fix.
Seems like most would pick the Kohler. I agree, Nothing wrong with Onan and there are lots around but the new Kohlers run very well with little maintenance. Its the same engine most "big" commercial mowers use so parts are easy to get. Kohler had some head gasket issues at first with the new V-style engines, but now seem to be great. Not to mention the new kohlers sound awesomeScott
HMW [Heavy Metal welding]
http://www.brweldingsupplies.com/par...ndex.cfm?ID=66Scott
Just got a new TB 302 with the Robin, only have 2 hrs. on it but will let everyone know if I have any problems with it. So far so good.
I figure when I get about 25 to 50 hrs. on it I will switch to synthetic as I use that in all of my other small engines.Trailblazer 302
Lincoln SP-135-T
Hobart Stickmate AC/DC
Smith torch
Spoolmatic 30A
Originally posted by ShieldArc View PostI wonder which engine is the quietest, or should i say the least irritating to listen to all day? Anyone know?Scott
Originally posted by ShieldArc View PostI wonder which engine is the quietest, or should i say the least irritating to listen to all day? Anyone know?The Kubota Diesels are 5db louder. Kohler,75.5 db....Robin 76.5db and the Kubota is 80.5db. Not too much difference.
I have to be in close proximity to a low rpm diesel extremely often. They can be just as irritating as a high rpm gasser. Been listening to the high rpm gassers for over 20 years now. They will bother you if you let them. Mind over matter....or noise.Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
