I am just a hobbiest but have a hard time machining a mig weld (mild steel) as it is so hard on bridgeport cutters. Any thoughts? Do I need to go with another process?
Machining a MIG weld
Is that big thing necassary???
I usualy have no problem with machining mig welds. They seem a little gummy at times. I usualy use no larger than 1/2 4 flute carbide cutter, in high gear low speed, with a coolant mister. A rougher mill will cut .500 deep full dia no problem, a straight spiral I never use more than 1/2 diameter and 1/2 the depth. With a manual machine I use steady pressure on the handle.Trailblazer 302g
coolmate4
hf-251d-1
super s-32p
you can never know enough
If those tips don't help, then your weldment has hardened considerably and needs to be annealed.
