Trailblazer Oil Levels
  • Trailblazer Oil Levels
    I have seen some conflicting info on the procedure for checking oil level on the dipstick. should it be read just prior to snaping the dip stick on the o ring. or should you snap it on the o ring pull it and read. Any help here would be appreciated. I also have some dirt deposits on the bottom plate.blown air is not removing it, too tight to get a vac or hand in there any ideas?
    2004 TB 302 w/ Kohler.
    Thanks
    MM
    Mountain Metal
    Coolmate 1
    Miller Trailblazer 302 W/ Kohler
    Miller Suitcase 12VS Wire feeder
    Weldcraft 26 TIG Torch
    Miller 210
    Spoolmate 3035
    Thermal Dynamics 51 Plasma
    Jet 7x12 L Cooled Band Saw
    Delta Drill Press
    Dewalt Chop
    I have always checked the oil level in Kohler engines with the dipstick in the normal running position. I take a thin rag and run it down the dipstick tube and then check the oil level. At least that is the way I was taught in Kohler factory mechanics school.
    [B]Trail Blazer 302
    Suitcase X-TREME 12VS
    Syncrowave 180SD
    Coolmate 4
    Millermatic 175
    Millermatic 251
    HT Powermax 180
    DeWalt DW872 Chop Saw
    Lathe
    Milling Machine
    Bandsaw
    No matter how hard I try, I always hear about the other guy who can do it better, faster and cheaper. Sure would like to meet him someday but no one seems to be able to find him when I ask. [B]
      Makes sense to me.
      MM
      Mountain Metal
      Coolmate 1
      Miller 210
      Spoolmate 3035
      Delta Drill Press
      Dewalt Chop
        according to kohler, you set the dipstick in put don't push it all the way down, and that's where you take your reading from. I think people often take readings when the dipstick is pushed all the way in or screwed all the way down (depending on M.Y.) and and therefore are running low on oil, which explains why so many people have low oil shutdown issues without know what the problem is, because as far as they are concerned the oil level looks fine, but in fact its at the bottom end of the level, now put your machine on a bit of a slope and you could be without oil pressure, hence the mysterious shutdowns.
        When you say dirt on the bottom plate, what exactly do you mean by bottom plate, do you mean the intake plate that the filter sits on, or the plate that the welder sits on? I clean my cooling fins with a stiff bristled brush and always try to clean up and oil drips to promote a clean and cool engine.
        hre
          The Kohler service manual says to fully seat the dipstick. See pic
            Coalsmoke,
            It was a while ago when I was messing with these things. You are right, the newer engines are supposed to be checked by placing the dipstick in the tube and rotating it counterclockwise till the cap drops down. Not really much of a difference but that is what the manufacturer says. Then again if it had a Briggs.....
            [B]Trail Blazer 302
            Syncrowave 180SD
            Coolmate 4
            Millermatic 175
            Millermatic 251
            HT Powermax 180
            Lathe
            Milling Machine
            Bandsaw
              Originally posted by acx780 View Post
              Coalsmoke,
              I think the 2004 Kohler is the same as the 05 Kohler where you do exactly as you described, do you happen to know when they switched to the screw cap? I know mine is an 05 and it has the screw cap. I think g5spfan might be referring to an older model with those instructions
              hre
                The manual I have was published in 2004 and appears to be a push cap type in the picture. Coalsmoke's must be the new type.
                  My early 04 302G had the push down, my mid year 05 302LP has the screw type.
                    Sorry about that then, I thought they changed over for the 04 year.
                    hre
                      im having a hard time getting mine rite,changed oil and filter,2 quarts of oil and seemed perfect.checked a couple days later and showed overfull,so drained a little out and looked perfect.worked yesterday and checked when i got to shop and it is showing low now.mine is screw type,and im checking by just setting cap on threads like manual says.
                        You'll find that with the exact oil installed as per data plate on the Kohlers, if you screw or plunge the dipstick in all the way in, you'll think that there is too much oil in your engine. This is checked after the engine is warm and ran up. now if you don't plunge the dipstick in or screw it in. The oil level is right on.
                        The oil level or pressure senders are finickly little buggers. Often if it senses a little oil present it allows the engine to work, but doesn't send any 12Vdc to the control boards to make them go.
                          thanks cruizer,im having a tough time getting right.sticker on hood says just set dipstick on threads,and im doing that and getting different readings.sticker also says 1.6 quarts,but im using the big napa filter.oh well i will get it.
                            Every engine in every thing I own seems different. In this case though, Kohler wants the dip stick pushed all the way in or screwed all the way in to get the proper level. Be careful not to overfill as too much oil (or especially oil that foams) will start to plug off the breather that drives the fuel pump starving your engine of fuel.
                            Have a great day!
                            John Leisner
                            Product Manager
                            Miller Electric Mfg. Co.
                            Owner and user of:
                            Trailblazer 302 and Legend 301
                            Smith Dual Guard oxy-fuel system
                            Various borrowed Millermatics and Spectrums.
