OK, I admit, this gets down right confusing, but the facts need to be put down on the table, written in black and white for all the world to see. What are the actually performance ratings on plasma cutters. Lets examine a few things...
1.) You have to have good clean power. 120V single phase might run your grinder OK, but for plasma, you need more power. 240V single phase is great for the small or home shop. For power users, you may want to have 240V or 480V three phase. We know that all the plasma manufactures make different size machines and have different input power requirements for each. This is a given, depending on your application and available power sources.
For my application, I have 240V single phase power available on a 50A 2 pole circuit breaker. Also, available Bobcat 225 NT has 10 KW of 240V 40A power on the panel.
2.) You have to have clean, dry air at the proper input air pressure (PSIG) and cubic feet per minute (CFM) for the plasma to work properly. OK, Miller has revised its requirements on a few models to show what pressure and air flow needs to be available to the connection port on the back of the machine as opposed to what the internal regulator of the cutter will allow.
For my application, I have 90 PSIG air available capable of flow to 5 CFM. I have a moisture trap I use with paint guns and will be purchasing a Motor Guard filter for the plasma. Adequate, clean, and dry air is not an issue.
Now the confusion starts. Cutting capacity of specified cutting units. Esab, Thermal Dynamics, Hypertherm, Miller, Hobart, Lincoln all have plasma cutting units available in various power ranges and sizes. We have seen all the hoopla over the new 27A portable units that weigh next to nothing compared the the regular 27A unit of similar size, i.e the Miller 375 and 375 Extreme,Thermal Dynamics PakMaster 38XL, Hypertherm Powermax 380 and Powermax 30, Lincoln Pro-Cut 25, and Esab Handy Plasma 380.
All of the above listed machines carry a rated capacity of 3/8", quality of 1/2" and sever or 5/8" inch using proper stand off from material, proper cutting technique and speed. This information is from the unit manufacturers. Some have reported what the factory reps have said or demonstrated at trade shows, the above mentioned cutting abilities.
Then we start reading how people can't get the same above machines to do what the factory guys say or show. What is the truth? Are the factory guys lying in their product literature? Are the demo machines at the trade shows souped up compared to what we can by at the LWS? Or are people trying to do things with their machines that they should not, such as operating outside the performance envelope?
My cutting application 90% of the time runs in the 1/8" to 3/8" range. On occasion, 5%, I will see 1/2". Cut length and duty cycle will indeed play a part in this. My cuts on the smaller sizes will be longer, 12" to 48" or more in total length. On 1/2", length will be just over 14" total run. (Hole for 4" Sch. 40 column pipe.) From the tech specs in the literature, I should be able to do my hole in the 1/2" plate within the 35% duty cycle at full 27A power on the 27A Class machine from any manufacturer. The pictured sever cut in the literature looks better than my O/A cuts in thinner metal.
For my application a 27A machine appears to do all I would want to do. A 40A machine would be nice and a 60A would be great, but space, portablity, and budget come into play. A 15% gain in duty cycle at 50% or 100% more price doesn't compute.
So what is the truth? Are the manufacturers ratings correct? Or are the ratings bloated by 2X, i.e. only half of what the manufacturers say? I want to hear from everybody on this. I want to hear from guys who only use their machine in the shop; those who take it everywhere with them; those who have been using the same trusty machine for years; those who get the latest toys because they have to have it; the guys that design them and build them. Lets the debate begin with input from everyone.
Lets get input and output about plasmas for guys like me who want to get one, have been reading up on them, asking about them, has an idea at what he wants, but is still confused about what to actually get. After all, this forum is about information and education.
Thank you and best regards to all who answer.
Charlie
Charlie
