I really only had a bad ground.
I was doing some salvage work this morning. I was scrapping out some transformers from a IBM AS400 Server and a Phone System power supply. The steel went to the scrap can and the copper went into the copper can. I had to use a combination of things to get the steel cut to where I could get the copper out, windings can be a pain. I had used the plasma to gouge the metal ends of the winding away to expose the copper windings. The smaller transformers weren't that big to cut away and were salvaged quite easy. I had one big one that was a challenge.
The bigger transformer had thicknesses that approached the limits of the Hypertherm 1000. Needless to say, I did have sparks and oxide flying while cutting through the laminations. Blow-back and varnish flare was a big problem. Smoked the end of the torch some, discoloration from the varnish burning and had to keep a wire brush handy to clean slag off the torch drag tip. As I was nearing the completion of my cutting, the plasma started show fault indicator and would not fire.
1.) Check Air supply. OK, clean and dry, no moisture in the trap and nothing collecting in the filter on the back of the machine. Regulator Set and Machine set to continuous cut.
2.) Check torch. Drag tip kept clean with wire brush. That's OK. Check nozzle and electrode. Nozzle looks good, not bad compared to new. Look at electrode. Has a small pit in the end. Consult manual. Doesn't look like 1/32" deep. OK, change nozzle and electrode to be safe. Hmmm, need some silicon on the threads, get the lube out. OK, gun looks good. Try it again.
WTH,
HOUSTON WE HAVE PLASMA!!!! Whewwwwwwww!!!!!!!! This thing is more finicky that the MM200 on ground.
Lesson learned and finally remembered reading it somewhere at one time... Make sure to have a good ground when using the plasma.
