For these little bandsaws, run it at the slowest speed for stainless. Also, buy a bi-metal blade.
The rule of thumb for teeth per inch (TPI) is 3 teeth engaged in the material at all times. So if the material is 1" thick, use 3TPI. For 1/4", use 12TPI. I think the smallest common size is 18TPI. It's hard to find blades that have more teeth than that. I keep a 14TPI and an 18TPI. The 14 is my workhorse. 18 works great for thin stuff.
I would suggest putting it into vertical mode and feeding the workpiece by hand to get a feel for how it should cut. Stainless takes a slow blade speed and a good amount of pressure to cut well.
