Dynasty 200DX - 1.5mm aluminium - settings
  • Dynasty 200DX - 1.5mm aluminium - settings
    First of all a quick hello, as this is my first post on the Miller site
    I am based in the U.K. and am a keen motorcyclist, and amateur fabricator of all things conected therewith.
    My current project is a 1989 Harris F1, here's a photo of the 'bike when I first got hold of it:
    I am rebuilding it from the ground-up, and have bought myself a Dynasty 200DX so that I can learn to weld, & fabricate some parts that I need. The next stage in the project is to build a seat sub-frame from 10mm (just less than half-inch) square tube.
    I would appreciate suggestions for some settings on the machine, to TIG weld 1.5mm (1/16th inch?) thick aluminium. I have some experience with MIG and gas welding, and have played around a bit with TIG and am making steady progress.
    Your help much appreciated,
    Regards,
    flatline
    Dynasty 200 DX...
    Use the Miller calculator to get yourself in the ball park. http://www.millerwelds.com/resources...calculator.php
    You will need a lot of practice before tackling a job like that. Also, bike frames are heat treated and you may/will weaken any existing structure that you weld to.
    Kemppi Pro Evolution 4200
    Kemppi 530 wire feed with MXE panel
    Kemppi ProCool ( coming soon)
    Cigweld TransMig 210se
    Cigweld TransTig 200 AC/DC
    Hypertherm PowerMax45
    CutSkill O/A setup
    Speedglas 9000x adflow
    Speedglas 9100xx
      Thanks for the advice mate. Fortunately the seat sub-frame bolts to the main chassis of the 'bike, so I can afford to make numerous attempts at building it without risking damage to the 'bike itself.
      Seems to be plenty of people 'viewing' my post, but only one or two guys seem to be forthcoming with advice
      Once again, many thanks
      FL
      Dynasty 200 DX...
        flatline,
        The reason many have "looked at" and not responded to your thread is because they don't know where to start.
        First off, what you're proposing is NOT an easy task for an experienced tigger. For a guy "just learning" the process, it may well be a long ways down the road before it can be accomplished.
        Tig welding thin aluminum (1/16") is NOT where you want to start. Simply giving you "settings" is not going to help much. I'll give you a start point, but you need to melt a lot of coupons before you tackle the seat bracket.
        AC
        Set frequency to about 120
        Postflow set to about 8 seconds.
        Amps to about 80. (You won't need it all but control with pedal)
        1/16" or 3/32" Tungsten sharpened to a crayon point (I prefer lanthanated or ceriated)
        Balance set to 75%
        No pulse
        1/16" 5356 filler
        I'd recommend getting some 1/8" coupon material and start there. Run beads in the flat position. When totally comfortable, move on to butt joints. Then work on your filet welds. When all this is "second nature", move on to thinner and thinner material. Jumping right into thin aluminum (1/16") will be nothing but frustrating.
        Be prepared to do a lot of "tungsten sharpening". To maintain the short arc you need, you'll do a lot of "dipping" as you're learning.
        Most (and I'm one of them) would recommend starting with mild steel coupons to develop the motor skills for tig.
        I'd also recommend going up to the top of the page and clicking on the "Resources" tab. There you'll find an offer for Miller's Student Pack. This includes an excellent Tig Handbook, a good GMAW Handbook and a bunch of other useful stuff. (not sure about European shipping, but the package is $25 w/shipping in the US) Best money you'll spend on tig welding.
        Syncrowave 250 DX Tigrunner
        Miller MM 251 w/Q300 & 30A SG
        Hobart HH187
        Dialarc 250 AC/DC
        Hypertherm PM 600 & 1250
        Wilton 7"x12" bandsaw
        More grinders than hands
          Hi Sundownlll,
          Thanks for the advice, really appreciate it. I understand that I'm embarking on a pretty steep learning curve - but I guess that's part of the fun.
          I have already ordered some educational materials from the resources area, and will take a look at the Student Pack that you recommended.
          I have had a couple of sheets of aluminium cut into handy 4"x2" test pieces for me to practice with, and will be making a start in the next couple of days. I'll post a few photo's of how I get on.
          Once again, thanks for your advice,
          FL
          Dynasty 200 DX...
            Don't forget to explore the rest of the "resources" tab, huge amounts of information available in pdf format.
              OK, Student Pack ordered, along with 'TIG Welding for Dummies', and the DVD 'TIG Welding Basics'.
              Should keep me busy for an evening or two.....
              p.s. what's a 'hack-artist' ???
              FL
              Dynasty 200 DX...
                A "Hack Artist" is American slang for someone who does poorly planned and sloppy or inferior work .Mike
                  progress...
                  Originally posted by SundownIII View Post
                  flatline,
                  AC
                  Balance set to 75%
                  No pulse
                  1/16" 5356 filler
                  Hi,
                  I am well impressed with Miller Electric, I ordered 'on-line' various educational materials from Miller on the 4th, and yesterday - Friday 7th january - everything arrived! ( I'm in the UK remember) - excellent service.
                  Set up my Dynasty 200DX as per SundownIII suggestions, after a couple of runs I increased Hz frequency to 125, but that was it, here's my 6th 'run':
                  Yeah, I know it's not a 'Stack of Dimes', but...
                  That's 1/16" thick aluminium, the two test-pieces are approx 6"x1-1/12", butt welded. Reckon my travel-speed needs a little work, and there's a little contamination at the r/h end of the weld, but this is pretty much my first session in the workshop, so I'm pretty happy with this as a start
                  Pedal control - an absolute must have, only just starting to get the hang of it, but already couldn't manage without it....
                  Any advice on eliminating the 'crater' at the end of a weld?
                  Cheers,
                  FL
                  Dynasty 200 DX...
                    Nothing like a picture to shut people up
                    Seriously,
                    There have been a number of posts about people repairing motorcycle frames. Think its simple? Take that aluminum that you welded (in the picture) and bend it and see where it breaks. My bet it brakes in the middle of the weld. Not your fault, just the nature of aluminum.
                    Step 1, contact the manufacturer. I know with cars with aluminum frames the manufactures have spec'd out procedures to do repairs. Maybe the same with motorcycles. You want to be able to decide which filler and if there are any gotchas. If you see other welds on the frame, that's a good sign that it was at least at one time, weldable.
                    As for welding parameters. I personally like lower frequencies especially if I can't get a backing plate. Higher frequencies - like 120, at least to me, seem like you go from, not enough penetration to fall out very easily. Try 80Hz. As you get closer to 60hz, the ability to keep a point supposedly goes down. In my limited experience, I have not found this to be a problem at 80-85hz. This is just my personal preference.
                    As for Amps, assuming soft squarewave, no pulsing, butt weld, try 65-70 amps on the dial. If your not forming the puddle fast enough, or the puddle is too small, bump it 5-10Amps at a time. I suspect you are going to need more, especially if you don't pre-heat. But after running a couple inches, there will be more heat than you need and you will want to feather back on the power. Look at your picture, see how narrow the bead was at the start... That to me is the toughest part of aluminum, making the weld good from the beginning to the end.
                    Balance of 75% is a good starting point. I would lean more to 80%.
                    1/16 or even .040 Lanthicated or Ceriated should be do able. The .040 is on the edge for these settings. With my 350, I have the EP to EN ratio at 75% so I actually put even less heat into the tungsten. I know I can do .060 aluminum with .040. Not sure about the dynasty 200 - keep an eye on it.
                    BTW, 3/32 is too big. I use 1/16 up to about 1/8" aluminum.
                    As for the crater at the end. One last dip of the filler as you slowly back off the amps.
                    For filler, You might be able to make .045 MIG wire work. But more likely you'll need 1/16.
                    Con Fuse!
                    Miller Dynasty 350
                    Millermatic 350P
                    -Spoolmatic 30A
                    Hypertherm PowerMax 1000G3
                      Hi con_fuse9,
                      The 'bike I'm working on - a Harris F1 - was hand-built in very limited numbers (about 6 of them, around 1987-89), fabricated from individual pieces of box-section alloy TIG welded together. The seat sub-frame that I want to build is a seperate item, bolted to the main chassis - so I've no concerns over messing up the original 'bike itself whilst I learn to weld.
                      The material I'm using is 1/2 inch box-section alloy, either 6082, or 6063 - 3/32" wall thickness. Tungsten is 3/32" 0.8% Zirconium, cup-size is 7/16", filler-rod is 3/32" aluminum with 5% silicone - shield gas is Argon.
                      I find that with a foot-pedal 80 Amps is fine, I'm only using all the Amps on start-up to get the puddle formed, then backing-off as I run the weld. 75% balance seems ok, I've tried playing around with this but it doesn't seem to make allot of difference - maybe I'm missing something(?).
                      With the frequency I'm finding 120Hz gives a more focussed arc, a more controlled weld puddle, and I can control penetration better with my travel speed. Early days yet, so maybe as my technique improves I'll come down on the Hz a little, but as you say - personal preferance maybe.
                      Thanks for the advice, it's still early days - reckon I'm going to need a fair bit more practice before I get to the skill-level that I'm looking for
                      FL
                      Dynasty 200 DX...
                        thats kinda crazy
                          Originally posted by vryndpndnt View Post
                          thats kinda crazy
                          What is it that's 'crazy' mate? - would be good to hear your opinion - cheers...
                          Dynasty 200 DX...
