If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I thought I'd start a thread about the firewall I plan to build for the "Z". Time to put the sheet metal tools to work. So far I'm just in the ''ideas" stage.
Before I start the firewall I wanted to get the English Wheel built. Ran into a little snag though. I made up the bottom anvil assembly last night. Cut the frame parts out today. Got a couple pcs. clamped together to weld.......and then stripped the threads out of the torch head on the TIG. and it's saturday.
There goes the weekend. ...............
Figured I would ask my questions here since this is the most recent thread...
Is that intercooler Water to air? I noticed the smaller set of bungs.
How are you setting up the steering column? Im going to take a wild guess that you are building in a crush point...but any ideas on that?
I also noticed youre going to be running a Turbo 400 with a transbrake (at least thats what it looks like...feel free to correct me)
A procharged 540 would move that car pretty good, might have a slight hesitation at idle though Oh, wait, that would be the cam.
Precision is only as important as the project...if you're building a rocket ship...1/64" would matter. If you're building a sledgehammer...an 1/8" probably wont.
Right on all counts. The steering column is built to NHRA rules. There's a stop at the firewall/cage, sfi tagged steering wheel disconnect designed to prevent the shaft from pushing up through the steering wheel. Judging by your user name you are probably aware of the rules on steering installation with IHRA & NHRA. So far the tech guys have been giving me a green light.
I dont know them off top of my head...but If I were building a car I'd definitely grab the rule book and a tech.
I picked the name cuz ive lit myself on fire so many times tangled up in cages and wrapped around differentials and other tight places. Canvas welding jackets, leather ones, lit a Lincoln welding helmet on fire once...
Gotta say though, you definitely take the time to do things right, and you seem to put some thought into what you are doing. I like builds like this. Its a race car...but if you really look close, its almost a show car.
Eventually I will post up some work on my new track car (87 Turbo 2 RX7) and my hot rod resto mod...(1970 C20 Long bed Chevy)
But for the moment, just trying to find enough side work to pay the bills and play a little bit.
Hats off sir!
Thank You. I'd like to see pics of the RX7 & long bed. I like following other builds also. I hope I can get some time in on mine this winter. Being self employed sometimes I get time sometimes I don't.
I haven't had a free weekend for months, but this weekend I
had some time so I started to assemble the car stands I've
been cutting out a little here & a little there.
I welded til noon, then cut down some trees & hung a door
for Jenni & J.D.(Daughter & Son-In-Law) then came back and
worked on the stands some more.
This afternoon I finished them up & jacked up the "Z". Made
some adjusters out of 3/4'' bolts, so I can level them. I wanted
to mark them so I could set the stand back on the floor in the
same spot each time & have them be level, so I made some
decals to keep them in the right locations. Also, the stand
decks are 15''x15'' , just the right size for the scales, so I
can weigh it on the stands if I get the urge. It's no hoist,
but it should make working on the "Z" a little more convenient.
For some reason i can't see the pics. Oh well sounds good anyhow. Do you have plans for the stands. I'm gonna need some soon for my volvo p1800. Maybe it will work if you PM them or something.
That's odd, they show up in your post. I use a MAC with Firefox.
I just made them out of some angle iron a friend of mine gave me so they are cheap. I like cheap.
I didn't make any drawings before hand, just cut them out and welded them up. They are basically just a box frame with cross bracing inside.
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
